November 11, 2025, 02:40:43 PM *
Author Topic: Things to get done while the engine is off the frame?  (Read 2095 times)
ishipwrecker
« on: May 09, 2023, 10:38:41 AM »
Howdy Gang,
So, I hydro-locked my engine last season and I'm just getting around to fixing it this year. I stripped teeth on the starter idle and drive gears; I need to replace those. I got the engine off the bike last night, but I have to hold off on cracking open the engine until I get a clutch gasket because I forgot it and only got the rear case gasket (I'm working outside so I want to open and close in one day).
I plan on doing the timing belt and alternator brushes & rubber; is there anything else I should take advantage of while I have the engine off?  Also, am I missing anything for this job? I looked through the manual, but maybe I'm missing something. I have the 2 gears, rear gasket with clutch on the way, starter motor O- ring, and the 12 point 46mm deep socket and a 32mm socket. I'll also get a new petcock, since I believe that started this whole nightmare.
Thanks.
« Reply #1 on: May 09, 2023, 10:48:32 AM »
New fuel rail o-rings, inspect and clean carbs.
Speedy Coop
South Wales, New York
« Reply #2 on: May 09, 2023, 02:26:00 PM »
Check out the rear case cover where the little shaft bosses are. I acquired a Vaikyrie  that had been hydro locked and beside damaged gears the rear cover damaged. I found a good  low mileage engine and that solved my problem. Hopefully your repair goes well.
ishipwrecker
« Reply #3 on: May 09, 2023, 03:10:07 PM »
Yes, I'll look into that too. Looks like redeye doesn't sell the carb set any longer?
I'll be sure to take a look at that,  and thank you.
« Reply #4 on: May 09, 2023, 08:05:09 PM »
Can't have a hydro lock with out two problems, the petcock leaking and floats not shutting off.
I would replace all the floats.
Consider a desmog while the engine is out, that's the easiest time to do it if you are going too. That choice is yours.
luftkoph
E U.P. Mich
« Reply #5 on: May 10, 2023, 05:45:51 AM »
Hats off to you sir, that is some extra effort with that rigging you did to suspend the bike, I believe most would have given up saying they cant do it outside. Much respect.
Some day never comes
RonW
Newport Beach
« Reply #6 on: May 10, 2023, 08:39:52 AM »
I didn't even see that when I read the post earlier. There's a wooden tripod suspending the bike!
2000 Valkyrie Tourer
ishipwrecker
« Reply #7 on: May 10, 2023, 10:37:33 AM »
Thanks. I'm not much of a carpenter, but it worked!
« Reply #8 on: May 12, 2023, 04:41:02 PM »
Agree, that is some amazing redneck engineering.  I am really impressed how you got it apart, of course I would never ever get that back together again!
« Reply #9 on: May 12, 2023, 05:16:59 PM »
the problem is the carb bowl vent lines not installed correctly or they have blockage to atmosphere.
see my post
https://www.valkyrieforum.com/bbs/index.php/topic,22852.0.html
« Last Edit: May 12, 2023, 05:21:16 PM by 98valk » Logged
Mooskee
Southport NC
« Reply #10 on: May 14, 2023, 11:41:00 AM »
Just to clarify, it is the float bowl needle valves that are worn out and not sealing. The floats are probably good. I have only replaced a float because it was embrittled and the plastic slot for the float bowl needle cracked.
I recommend getting OEM float bowl needles or K&L 18-8955.
I wish you the best for your project. I always appreciate someone saving one of these bikes.
