March 21, 2026, 11:57:10 AM *
Author Topic: FYI; RECALL 500k at home COVID tests  (Read 1123 times)
Jersey mike
Brick,NJ
« on: May 10, 2023, 04:11:25 AM »
I’m not trying to stir the pot but some here may have this at home. Apparently this was released May 4th.
Here’s the link and a portion of the release. Lot numbers are in the press release.
https://www.fda.gov/medical-devices/safety-communications/do-not-use-certain-sd-biosensor-pilot-covid-19-home-tests-fda-safety-communication
Date Issued: May 4, 2023
“The U.S. Food and Drug Administration (FDA) is warning consumers and health care providers to stop using and throw out certain lots of recalled SD Biosensor, Inc. Pilot COVID-19 At-Home Tests, distributed by Roche Diagnostics. The FDA has significant concerns of bacterial contamination in the Pilot COVID-19 At-Home Test liquid solution, provided in the test kit. Direct contact with the contaminated liquid solution may pose safety concerns and the bacterial contamination could impact the performance of the test.”
“SD Biosensor, Inc. has initiated a recall for all impacted SD Biosensor Pilot COVID-19 At-Home Tests that were distributed by Roche Diagnostics to certain retailers in the United States. Approximately 500,000 tests were distributed to CVS Health, as well as about 16,000 tests to Amazon. The FDA is working with Roche Diagnostics to understand how many of those tests were sold to consumers.”
“Importantly, none of the impacted lots were distributed through COVID.gov/tests - Free at-home COVID-19 tests or as part of other federal testing programs. If you received your tests through the COVID.gov/tests distribution or as part of other federal testing programs, they are not subject to this safety communication or product recall.“
“ Recommendations for Consumers, Test Users, and Caregivers
Check to see if your SD Biosensor Pilot COVID-19 At-Home Test is included in the SD Biosensors product recall by comparing the lot number.
Do not use test kits with the affected lot numbers listed above. Throw out the entire test kit in the household trash.
Do not pour the liquid solution down the drain. Additional information can be found in the Quick Reference Instructions for patients.
If the liquid in the tube contacts your skin and eyes, flush with large amounts of water. If irritation persists, seek medical attention.
Watch for signs of bacterial infection caused by exposure to the contaminated liquid solution. If you see signs of infection, such as fever, discharge, red eyes, or any other concerning symptoms, seek medical attention.
Talk to your health care provider if you think you were tested with an affected Pilot COVID-19 At-Home Test, or if you have concerns about your test results.”
“ Potential Risks”
“The liquid solution provided in the affected Pilot COVID-19 At-Home Test kits has been found to be contaminated with organisms such as Enterococcus, Enterobacter, Klebsiella and Serratia species. Individuals performing the self-test may run the risk of direct contact with the contaminated liquid in the tube. The liquid is contained in an individual, ready-to-use, pre-filled and sealed tube, but a user may inadvertently come in direct contact with contaminated liquid buffer during opening the tube or handling of the open tube or while performing the test.”
“ Infection from bacteria such as Enterococcus, Enterobacter, Klebsiella and Serratia species may cause illness in people with weakened immune systems or those with direct exposure to the contaminated liquid solution through standard handling, accidental spills, or misuse of the product.”
« Reply #1 on: May 10, 2023, 04:55:35 AM »
The government ones (from china) are fine. Wink wink. Glad I sent mine back to Mr Biden.
« Last Edit: May 10, 2023, 05:13:25 AM by Chrisj CMA » Logged
« Reply #2 on: May 10, 2023, 06:10:33 AM »
I had not considered doing that.  Thanks for the idea.  Will set it up this week.  Biden needs them.
« Reply #3 on: May 10, 2023, 08:20:45 AM »
      Ship it Signature REQUIRED for receipt!  2funny RIDE SAFE.
