December 28, 2025, 11:18:27 AM *
Author Topic: Found a Caliper PIN PLUG replacement plug  (Read 2357 times)
« on: May 14, 2023, 05:19:34 PM »
 Found a Allen Socket Head Plug to replace the OEM flat screw driver plug.
0.5 mm longer than oem but not a problem. Socket end could be shorten some if one wanted to.
after install I put a chrome cap into the allen socket.
https://www.fittings.space/gsm13-m10x10m-sc
Metric Fitting M10 M10X1 Male Thread Allen Socket Head Plug Black Steel
WintrSol
Florissant, MO
« Reply #1 on: May 14, 2023, 08:48:57 PM »
Nice find. The originals can be a real problem after spending 20 years in there.
« Reply #2 on: May 14, 2023, 09:42:08 PM »
Nice find but $4.99 for black steel is no bargain. I’d pay that for SS.
« Reply #3 on: May 15, 2023, 04:39:43 AM »
OEM is black steel and basically same price as the ones I found.
"when dissimilar metals come in contact, the chances of galvanic corrosion arise. The same is the case with aluminum and stainless steel.
Apart from the two dissimilar metals, there is a need for an electrolyte that provides an appropriate environment for galvanic corrosion. In the case of aluminum and stainless steel, the moisture in the air or the water works as an electrolyte."
https://www.metalworkmasters.com/materials/stainless-steel-screws-in-aluminum/
baird4444
« Reply #4 on: May 20, 2023, 06:12:49 PM »
a metric grease zirk will work as well.
    - ya gotta be SOBER!
     -Cody Baird
« Reply #5 on: May 20, 2023, 06:17:45 PM »
Sandy, I bought a pack of stainless ones a few years ago. I believe I still have some. If you need, let me know.  cooldude
