« on: May 18, 2023, 02:02:19 PM » |
What size are the vacuum cap plugs we use for desmogged bikes?
Think I found it and answered my own question, 3/16". Sounds right, let me know if not. Thanks.
« Last Edit: May 18, 2023, 02:32:27 PM by Valkorado »
« Reply #2 on: May 18, 2023, 03:06:13 PM » |
No clamps needed? How long do they hold up? I'm just looking for either a long lasting set that can handle the gas and heat (viton, maybe?) or just get a bunch of 'em bulk. The flexible rubber ones sure get hard as a rock after a season.
« Reply #3 on: May 18, 2023, 03:20:14 PM » |
I like the oem caps too. They last a good long time. You're supposed to use a tube clip (one of those circles of wire) with them. They're on the cylinder head fiche page.
« Reply #4 on: May 18, 2023, 03:32:06 PM » |
Thanks, I'll give them a try. I found some that look like the BonS ones I'd been using, without the clamps. https://www.ebay.com/itm/110976169922?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=iVeTC0yARpe&sssrc=2349624&ssuid=EkcgiTXYSz6&var=&widget_ver=artemis&media=COPYI was thinking I'd just reuse Bon's spring clamps and buy a bunch in bulk cheap, but changing them out seasonally gets old. These are more spendy, but if they last longer they'll be worth it. The cheapies could be good to pack in a saddlebag just in case, tho.
« Last Edit: May 18, 2023, 03:34:56 PM by Valkorado »
« Reply #5 on: May 18, 2023, 08:30:19 PM » |
On my former Valk, I took one of the nipples out and matched it up with a metric bolt and crush washer. No caps to blowoff. I then carried the nipples in a small ziplock under the seat.
« Reply #6 on: May 18, 2023, 08:34:53 PM » |
yep same here except I used allen head screws.
« Reply #7 on: May 18, 2023, 10:10:50 PM » |
This sounds interesting as well. I'm thinking the nipples would only be needed for the occasional rare carb synch?
« Reply #8 on: May 19, 2023, 05:11:27 AM » |
This sounds interesting as well. I'm thinking the nipples would only be needed for the occasional rare carb synch? yep u got it. still need #6 hose connection for the vacuum petcock.
RonW
« Reply #9 on: May 19, 2023, 05:59:59 AM » |
« Last Edit: May 19, 2023, 07:52:14 AM by RonW »
2000 Valkyrie Tourer
