December 28, 2025, 11:18:43 AM *
Author Topic: 200K timing belt change  (Read 2009 times)
clanky
« on: May 28, 2023, 08:46:53 AM »
I'm coming up on 200K on my 98 Standard and will install the third set of timing belts.  I'm not sure but I suspect I might possibly have a tension pulley that might be running a tad rough.  Has anyone changed the bearings on the timing belt tension pulleys on this engine or do I just cough up the $85+ for a tension pulley assembly?
RonW
Newport Beach
« Reply #1 on: May 28, 2023, 09:05:31 AM »
Perhaps, the pulley's bracket is the expensive part. Others will chime in on a tensioner replacement.
« Last Edit: May 28, 2023, 09:29:20 AM by RonW » Logged
2000 Valkyrie Tourer
« Reply #2 on: May 28, 2023, 10:41:09 AM »
there are holes in the backing plate which allows a small amount of grease to be added with a needle fitting.  or find a low mileage set on ebay many are selling low mileage now running bikes on there. estate sale/s, owner passed away, etc. the ebayers can make more money parting them out than getting it running and selling it. I've picked up some low mileage items over the yrs.  GL1200 are the same as the GL1500.
« Last Edit: May 28, 2023, 10:59:53 AM by 98valk » Logged
Ken aka Oil Burner
Mendon, MA
« Reply #3 on: May 28, 2023, 03:21:58 PM »
This is my thread on the subject. Hope it helps.   http://www.valkyrieforum.com/bbs/index.php/topic,110100.0.html
clanky
« Reply #4 on: May 29, 2023, 01:30:15 PM »
Thanks Oil Burner! Excellent set of pictures. I'm going to do this mod!
