January 30, 2026, 09:22:10 AM *
Author Topic: I/S tail light conversion  (Read 4035 times)
Challenger
« on: January 31, 2010, 05:17:00 PM »
I'm installing a Std tailight on my I/s (Super Valk Mode) and need to wire into the system for the brake lights, Does anyone know if #7 on this parts finder is the right harness? $9.00 seems better than cutting into mine       http://www.hdlparts.com/fiche_section_detail.asp?section=148895&category=MOTORCYCLES&make=HONDA&year=1999&fveh=3478
« Last Edit: January 31, 2010, 05:21:29 PM by Challenger » Logged
« Reply #1 on: January 31, 2010, 05:51:16 PM »
That's right. #7 is the rear fender harness. #6 is also needed to get from the fender back to the side cover if you want to tie in the wiring there. If not, just cut off the forward plug (on #7) and splice from that point.
Joe Hummer
Arnold, MO
« Reply #2 on: January 31, 2010, 05:59:05 PM »
I will be doing this same swap in a couple of weeks.  I plan on splicing in some couplings into the brake wiring so the owner can still put the trunk on when he wants.  If you butcher the stock IS brake wiring, you can't connect the trunk wiring.
Joe
1999 Valkyrie Interstate
Chrome
London Ontario Canada
« Reply #3 on: January 31, 2010, 06:25:15 PM »
Hey Challenger I am also wiring up a standard brake light to my I/S. I disconnected the brakelight wire from the trunk and am replacing the whole harness with a new one but disconnecting one of the ends.I just ordered this harness(Under 10 bucks thru HDL) so I haven't done it yet.This way I just have to unplung under the right cover when the trunk goes back on. It is item #9 in this fishe  http://fiche.ronayers.com/Index.cfm/Module/Main/TypeID/26/Type/Motorcycle/MakeID/1/Make/Honda/YearID/41/Year/2000/ModelID/6800/Model/GL1500CF/GroupID/289816/Group/WIRE_HARNESS
Happy Trails Adrian(Chrome)V
2001 Valkyrie I/S
1999 Valkyrie I/S
1998 Ace Tourer
1984 V45 Sabre
1976 CB 750 SuperSport
1969 CB 750 Chopper
Challenger
« Reply #4 on: January 31, 2010, 07:10:10 PM »
I figured that since the trunk plugged in a seperate connector, I could just switch the I/s fender harness (for the turn and lic plate light) with the Std harness Which Would have the brake light wires and connectors, and leave on all the time. But I see now I may need #6 also to get the brake wires.
BradValk48237
Oak Park, MI
« Reply #5 on: February 01, 2010, 03:27:17 AM »
Dang!!   If everybody goes Super Valk, I will have to put the trunk back on just to be different! 2funny
 Actually, I think it keeps down the buffeting and make for a better ride.
B
Kingbee
VRCC# 576
Northern Illinois
« Reply #6 on: February 01, 2010, 07:02:27 AM »
Why are some of you worrying about disconnecting the tail light when the trunk is on the bike?
Run it with the trunk.
1999 Interstate
2000 Interstate
2004 Rune
Joe Hummer
Arnold, MO
« Reply #7 on: February 01, 2010, 07:26:33 AM »
Hey Kingbee,
I don't think you have quite enough light on the back of your bike.  Think you could add a little more?
Next question...does your motor bog down when you hit the brakes?
Cheesy
Joe
Challenger
« Reply #8 on: February 01, 2010, 02:58:45 PM »
Kingbee, That's what I'm going to do, leave on for extra light when trunk is on for touring, I stillwant to be able to unplug it fopr fender removal if needed, I liked the looks of yours last fall in PDC, Too many rear enders latley and I'm getting more saftey concious all the time (Is that old age creeping up?)
John U.
Southern Delaware
« Reply #9 on: February 01, 2010, 08:08:11 PM »
That's not the only thing creaping up. My big worry these days is cell phone saturation. Seems like 25 to 30% of the driving public is on their phone at any given moment.
I installed a Standard/Tourer tail light on my I/S also, even though I have no intention of Super Valking it. Bought a Radiantz LED cluster to run in it, really bright. I'm thinking of installing a Signal Dynamics brake light flasher also.
Kingbee's smart to have all those lights, might save your azz someday.
Rocketman
Seabrook, Texas
« Reply #10 on: February 02, 2010, 03:05:16 AM »
Just so I'm clear, to put the tourer style taillight in and leave the trunk lights operational, I need to replace these parts:
IS SubHarnessA: 32102-MBY-000
IS SubHarnessB: 32103-MBY-000
with these parts:
Tourer SubHarnessA: 32102-MZ0-000
Tourer SubHarnessB: 32103-MZ0-000
And then plug in my taillight, and all's good?
(I'm not in a position to go out and look at the bike, so I can't verify this on my own.)
Joe Hummer
Arnold, MO
« Reply #11 on: February 02, 2010, 04:49:59 AM »
with these parts:
Yes...and you will have to splice some wires into the brake circuit so that it will power your tourer taillight.  The trunk has its own plug.  Or at least that is how I see it being done...having not actually done the work yet.  So...you can say...that is how I plan to do it.
Joe
Kingbee
VRCC# 576
Northern Illinois
« Reply #12 on: February 02, 2010, 05:45:24 AM »
Yes, I did the flasher mod, but just to the LEDs, for contrast
Back off flasherpowered by Aeva
1999 Interstate
2000 Interstate
2004 Rune
John U.
Southern Delaware
« Reply #13 on: February 02, 2010, 03:38:59 PM »
with these parts:
Joe
I was going to use the subharness when I wired my Tourer tailight. I even bought the two wire harness's I fighured I needed. Once I removed the wheel and actually started the project i changed my mind. Since I don't plan to remove the trunk and I was going to have to splice the tail, brake light and ground wires anyway, it just seemed easier to run 3 16 gauge wires. I soldered the connections and ran the wires in a piece of vinyl tubing to the grommet where they pass through the fender. I zip tied the vinyl tube to the existing wire bundle. It was pretty quick and easy. If it ever fails, I still have the harness's I never used.
Rocketman
Seabrook, Texas
« Reply #14 on: February 02, 2010, 04:11:26 PM »
It looks to me like using those wiring subharnesses takes care of any splicing for you.  The only question in my mind is if the plug on the IS subharness A matches the plug on Tourer subharness A.
Am I way off base?
Joe Hummer
Arnold, MO
« Reply #15 on: February 02, 2010, 04:22:23 PM »
from my research, the end that connects to the bike is single pin connectors.  The main harness on the Tourer/Standard has 6 (i believe) pin connectors.  On the IS, it is 4 pin connectors for the signals/lights and the connector for the trunk lights.  I don't have any empirical data yet, but will have next weekend.
Joe
BradValk48237
Oak Park, MI
« Reply #16 on: February 02, 2010, 05:07:54 PM »
On my i/S I spliced the tail light into the trunk harness and added a quick disonnect plug for the trunk and a 4 pin connector for the speakers.... Left the pin connectors under the fender for removal. Drop on the trunk, plug in the 3 under the seat, tighten the bolts and drop on the seat..... 5 min and back to normal.
Rocketman
Seabrook, Texas
« Reply #17 on: February 10, 2010, 12:05:19 PM »
Joe
What did you come up with?
Joe Hummer
Arnold, MO
« Reply #18 on: February 10, 2010, 12:11:36 PM »
Joe
Haven't done it yet.  It is scheduled for this weekend (not doing my bike).  I will post pictures when completed.
Joe
