December 28, 2025, 11:18:21 AM *
Author Topic: O rings for water pump '99 Tourer  (Read 1797 times)
sidecarwilliam
SF Bay area
« on: June 03, 2023, 09:46:59 AM »
I had a small problem that just grew large for me.
I had a leak at the O ring on the water pump on my '99 Tourer. I removed the water pump and ordered the O rings from Patrzilla.
Today I am informed the O rings are not available at this time. crazy2
I am leaving (or was leaving) on a trip back though Iowa and  Mississippi etc. in two weeks.
Anyone got any ideas??
bill.
Oh, and the local Honda has them on order also, but...
3W-lonerider
Shippensburg Pa
« Reply #1 on: June 03, 2023, 10:09:00 AM »
local shop that makes hydraulic hoses normally has an assortment of orings available. might check with them.
Mooskee
Southport NC
« Reply #2 on: June 03, 2023, 10:13:16 AM »
I f you still have the old O-rings and a set of calipers you could measure the ID, OD, and thickness of the O-rings and order them online. You should be able to get quick shipping.
sidecarwilliam
SF Bay area
« Reply #3 on: June 03, 2023, 10:18:29 AM »
Thanks for the quick feedback.
I just called the local Honda shop as they just opened and it appears they forgot to call me yesterday when the parts came in.
Problem solved.  Trip back on.
Again thanks to all.
bill.
Mooskee
Southport NC
« Reply #4 on: June 03, 2023, 10:39:13 AM »
Allright! Great news. If you have the means to get the measurements of the O- ring; it would be great if you posted it here.
I got this off the parts sites, but am not sure if it is the measurements. Seems to be missing a number.
O-RING (32.95X2.62) (ARAI)
91302-MB0-013
Honda
If we had the replacement info it could be available for the next time someone has this issue.
sidecarwilliam
SF Bay area
« Reply #5 on: June 03, 2023, 07:13:54 PM »
I have three more sets coming from Honda and if someone needs one I will be happy to send them.
If you like I will send one set to you and you can measure them and and let everyone know.  No charge from me.
bill
ridingron
Orlando
« Reply #6 on: June 03, 2023, 08:49:25 PM »
I presume item #12
91302-MB0-013
https://www.partsfish.com/oemparts/a/hon/506c2f67f870023420a31b34/water-pump
Mooskee
Southport NC
« Reply #7 on: June 03, 2023, 11:18:13 PM »
bill
Bill, I would be happy to do so.
Dave Morgan
150 N Shore Dr
Southport NC, 28461
I will see if I can measure them and get the info posted here. Should be able to find a generic replacement for part #12. The gasket is a different story.
RP#62
Gilbert, AZ
« Reply #8 on: June 05, 2023, 04:18:47 PM »
In a bind, you could probably make a gasket and use it instead of the o-ring.
-RP
