« on: June 20, 2023, 07:28:49 AM » |
I was looking for some other stuff yesterday to do some work under the house. As I rummaged through my "storage" containers in the garage, I found this device. I know what it's for. But don't ever remember using it.  So, I am going to see what I can find out. Any suggestions appreciated.
« Reply #1 on: June 20, 2023, 07:46:31 AM » |
I had one and used it, until the multi-channel digi-sync came out which works much better on the valkyrie.
the twin max works very well for 2 cylinder engines, BMW owners will buy it from you.
« Reply #2 on: June 20, 2023, 07:49:42 AM » |
 I will probably keep it......
Thunderbolt
« Reply #3 on: June 20, 2023, 09:31:36 AM » |
I still have one although I don't own any multi carb bikes. It worked very well. It's a differential vacuum gauge. You put one side on #5 if I remember right, anyway the carb with no adjustment. Put the other side on the others in succesion and adjust them to move the needle the same amount either side of zero with the engine running at idle. We had several carb adjustment parties here. Amazing how the engines smooth right out once they are pulling the same amount of vacuum on all cylinders. Sometimes it was necessary to adjust the idle afterwards or during the process.
« Last Edit: June 20, 2023, 09:33:10 AM by Thunderbolt »
« Reply #4 on: June 20, 2023, 11:11:00 AM » |
Thanks for the information Thunderbolt. I do not believe I have ever synched the carbs on the my 2003 Standard. But then Its been a few years.
« Reply #5 on: June 20, 2023, 02:34:05 PM » |
I believe #3 has no adjustment.
« Reply #6 on: June 20, 2023, 05:05:32 PM » |
The twin max works well once you understand how it works and what you are doing. I now have a digi sync but I also still have the twin max. Read the directions and do a lot of throttle blipping before you call each cylinder synced. Upping the sensitivity as you go is very important.
« Reply #7 on: June 20, 2023, 05:57:01 PM » |
Ramie
« Reply #8 on: June 20, 2023, 06:34:16 PM » |
Looks like they still sell them. https://twinmax.us
“I am not a courageous person by nature. I have simply discovered that, at certain key moments in this life, you must find courage in yourself, in order to move forward and live. It is like a muscle and it must be exercised, first a little, and then more and more. A deep breath and a leap.”
« Reply #9 on: June 20, 2023, 06:51:15 PM » |
Yes it's the first thing I did, check to see if they still were in business. I wish I knew how old mine was, just out of curiosity.
h13man
Indiana NW Central Flatlands
« Reply #10 on: June 21, 2023, 07:11:19 AM » |
I use a homemade fluid balancer commonly called a Beemer Gauge. I like to have mine synched with the 6 channel variant just to see the difference.
