January 30, 2026, 08:01:22 AM *
Author Topic: Front Wheel Removal  (Read 2216 times)
Red Diamond
Beaumont, Texas
« on: February 01, 2010, 07:05:33 PM »
Has anyone tried removing the front wheel assembly without removing the brake calipers or just removing one brake caliper?
Joe Hummer
Arnold, MO
« Reply #1 on: February 01, 2010, 07:08:57 PM »
You can't do it.  The brakes will hit the sidewalls and you won't get the tire past it.
You only have to pull one side off.
Joe
1999 Valkyrie Interstate
Red Diamond
Beaumont, Texas
« Reply #2 on: February 01, 2010, 07:23:15 PM »
Thanks Joe, after I did my wheel swap, I saw the one caliper removal done on a Goldwing. I was just wandering whether that technique would work on a Valk. I was thinking the removal of both calipers was a bit much.
« Reply #3 on: February 02, 2010, 08:08:00 AM »
Removing both calipers makes doing anything with the wheel a whole lot easier including reinstalling the wheel.
I simply use a bunji cord of the correct length to hang the caliper from the handlebars.
It is wise to tie the handlebars with a cord so they do not rotate, regardless of what you are contemplating doing with the front end.
