November 11, 2025, 12:30:41 PM *
Author Topic: I’ve got a buzz  (Read 1942 times)
CamTom12
VA
« on: July 05, 2023, 06:07:19 PM »
I’ve got a buzz in the front somewhere, but the bolts in that long tube behind the rad are tight. Anywhere else I should look?
« Reply #1 on: July 05, 2023, 06:26:04 PM »
The buzz bolt buzz is not the bolt at all, but the long spacer surrounding it between the frame members.
A wrench on that bolt (nut) may feel rock solid tight, but if the spacer between the frame members is loose enough, it will buzz (sometimes badly).  When I tightened mine (the 2d time), I cranked on it with all I had, and it squeaked (not to worry it's tool steel).  I believe I had to actually compress the frame members to securely capture that long spacer to stop my buzz (a rattle actually).
When tightening, you need not get a tool on each side, just a wrench or socket on the nut side (right).
If it's not this, a front brake caliper will often make noise (like the little clip holder is loose, or the pin the floating rotors move on needs some lube).
« Last Edit: July 05, 2023, 06:29:39 PM by Jess from VA » Logged
CamTom12
VA
« Reply #2 on: July 05, 2023, 06:51:13 PM »
Should I give it a tty with a breaker bar? Definitely felt rock-solid with a normal 3/8” ratchet.
da prez
Wilmot Wi
« Reply #3 on: July 05, 2023, 06:54:05 PM »
Loosen before tightening.
                                     da prez
CamTom12
VA
« Reply #4 on: July 06, 2023, 03:21:30 PM »
                                     da prez
Will do, thanks!
« Reply #5 on: July 06, 2023, 06:22:10 PM »
Others have removed the bolt and spacer, added some RTV inside the spacer and reinstalled the bolt, once the RTV cures, the spacer no longer buzzes.
CamTom12
VA
« Reply #6 on: July 06, 2023, 07:08:49 PM »
I like that idea better than pinching the frame. Added RTV as in filled it up, or as in just enough to dampen the vibe?
« Reply #7 on: July 07, 2023, 04:39:13 AM »
I wouldn't fill it, just in case you have to ever DI's-assemble it.  I would think a little on each end should do it.
