May 07, 2026, 05:24:21 AM
1800 Tech Board
Topic: . (Read 9200 times)
July 09, 2023, 09:02:53 AM »
Last Edit: August 06, 2023, 12:03:45 PM by Britman
Re: Rear brake pad remove, replace
July 09, 2023, 07:31:55 PM »
If it is not too late you could use hydraulic preasure to
push the pistons out some and clean them... then maybe
remove the reservoir cover and see if that makes it
easier to push them all in. I always watch the open reservoir
to make sure it doesn't overflow when I'm pushing the
pistons in, but I not sure that would ever really happen...
Firefight100
USA
July 09, 2023, 09:00:18 PM »
yes you have to remove the wheel first. A c clamp on the old pad will reseat the pistons in.
