March 21, 2026, 06:42:36 AM *
Author Topic: Brass inserts  (Read 1298 times)
« on: July 12, 2023, 03:40:34 PM »
I honestly don't know whether this rightfully belongs on the PaM board, the Tech board or the General.
I just finished putting the fairing back on an Interstate.  Normally I try to avoid criticizing the Honda designers as they created a beautiful, a wonderful machine.
However, I wonder who was the imbecile that thought it was a good idea to put brass inserts into an ABS part to be held in place with steel screws?
I fixed two after the removal.  I discovered two more on the reinstall but decided to let them be until next time.  I have a fair amount of anti-seize on fingers on both hands.
They do look good when they're all back together.
P.S.  After I've completed I found a screw in my pocket.  I can't see where one is missing but there must be.
« Last Edit: July 12, 2023, 04:01:20 PM by Willow » Logged
« Reply #1 on: July 12, 2023, 03:49:53 PM »
Ugh, one of the biggest complaints I had when I had Interstates were those awful things...
I JB Welded most of 'em in real good and anti-seized the screws on mine. Hope the new owner's appreciate all the work! Heh...
« Reply #2 on: July 12, 2023, 05:06:42 PM »
    Yuppers been there done that anti seize on digits too!  2funny And like Serk I glued them back in and hope next caretaker of Phatt Ghurl has similar appreciation of that particular chore!  cooldude RIDE SAFE.
« Reply #3 on: July 12, 2023, 06:22:18 PM »
As I recall, the '99 Valk Interstate was rushed to market.
Honda had the successful 1500 Gold Wing and refined it over 12 years to precede the Valk.
The Valk engine and chassis was a solid and reliable Honda performer (and still is), but they made some foibles rushing the Interstate to production.   And the faring inserts are one of them.  When you look at them, you wonder how the thing doesn't fly off in the wind.  Speaking of which....
The saddle bag cables are another example.  They work well enough until they break (a look at the parts fish shows the rubics cube of the cable assembly).  With no working bag cables on one side, I had the occasion to hit a hard jolt on the freeway, the lid clamp in front let go, the air got under the leading edge, and the rear lock did nothing to stop it from departing the bike and sailing (then scraping) down the edge of the road.  Despite traffic, I nailed the brakes, stopped, and began running back down to retrieve it.  Alas, someone got over to the edge and ran it over (smithereens) before I got to it.  I felt like I was in a Roadrunner movie.   crazy2 Grin Tongue
The only thing missing was a cop to catch me running around on the freeway.
The price of a painted lid (when you could still get them), and the hardware is high.  So is getting a used one and having it repaired and painted at the bump shop (what I did), and all new OE hardware/cable assembly.
Take care of your cables.
PS:  If you have the bag rails, you can delete the Interstate saddlebag hold-offs, which interfere with fully loading a bag for travel.  The lids lay on the top rail and won't scuff paint.
https://www.procaliber.com/oem-parts?aribrand=HOM&arian=MOTORCYCLE#/Honda_Powersports/GL1500CFA_(99)_VALKYRIE_INTERSTATE%2c_USA%2c_VIN%23_1HFSC410-XA000001/SADDLEBAG/61347acc-638e-40e4-aa4f-0fceb839ab88/34557c9a-e4ac-4516-a4eb-207841eaa5d4/y
« Last Edit: July 12, 2023, 06:37:41 PM by Jess from VA » Logged
Avanti
Stoughton, Wisconsin
« Reply #4 on: July 12, 2023, 07:39:45 PM »
The same screws are used for the WINDSCREEN GARNISH inside the fairing as are used for the left and right COWL PANELS.
Moonshot_1
« Reply #5 on: July 12, 2023, 07:57:48 PM »
I have battled with those things before. Headlight bulb replacement. I was not amused. Got it done but not amused.
This year had a speedo light go out. 99 Interstate.
Had the dealer replace it when they did the oil change just because I didn't want to deal with them inserts again. Pretty sure if I tried they would have to fix it anyway. So I just cut to the chase.
Willow we need a separate board just for this. And maybe OEM valve stems. LOL
Mike Luken
Cherokee, Ia.
