High Desert
« on: July 15, 2023, 08:42:17 AM » |
Are there adjustments I can make to soften the ride on my (non standard) standard? I have modified it a bit but the only things I believe I did that could impact suspension is (1) I lowered the back with a set of 11.75” shocks and (2) I lightened it up a bit by removing stock fenders/seat/lights etc ( see Pristine Parts in the classifieds). Am also running dark side. But, all this would affect the rear suspension in my mind, and the bit of a jolt I feel seems to be in both front and rear. First Valkyrie so maybe this is normal(?).
« Reply #1 on: July 15, 2023, 09:23:16 AM » |
your rear tire most likely is hitting inside the upper fender where it clears the shock tower cross bar with the shorter shocks. front suspension, lower oil level some and /or change oil weight. now since fork oil weights are not standardized like motor oils it, it can be a lot of tuning to what u like. viscosity of the oil is best way to tune and not the weight. https://www.peterverdone.com/suspension-fluids/
« Reply #2 on: July 15, 2023, 10:04:01 AM » |
Lower shocks mean less travel and a harder ride.
I like my tires hard (near max PSI on the sidewalls), and that also means a harder ride.
Less air gives a softer ride, but less longevity of tires.
WintrSol
« Reply #3 on: July 15, 2023, 11:56:55 AM » |
And harder tires give less grip for braking. It's a trade, all around.
98 Honda Valkyrie GL1500CT Tourer Photo of my FIL Jack, in honor of his WWII service
« Reply #4 on: July 15, 2023, 12:57:41 PM » |
And harder tires give less grip for braking. It's a trade, all around.I know, but new(er) hard tires stop pretty well. I'm pretty good at avoiding hard stops. But the idiots are everywhere.
High Desert
« Reply #5 on: July 15, 2023, 06:56:41 PM » |
Thank you for the suggestions so far. Note I have replaced the fenders with a tracking fender so my travel is probably diminished even more for the rear wheel. I will play around with the viscosity grades in the front, where I really think I am experiencing more of the bumps.
Here’s a pic if it helps with any more good ideas:
« Last Edit: July 15, 2023, 07:06:58 PM by High Desert »
« Reply #6 on: July 15, 2023, 07:15:54 PM » |
LOL! That's a very nice build but if you built that expecting a softer ride you are likely destined for disappointment.
It is sometimes difficult to determine whether suspension bumps are coming from the front or the rear. With that setup bumps from the rear are pretty well guaranteed.
ridingron
« Reply #7 on: July 15, 2023, 07:23:55 PM » |
What do you need rear shocks for? You have springs under the seat!
High Desert
« Reply #8 on: July 16, 2023, 06:08:59 AM » |
So not being too familiar with shock adjustments, I’m going to swing the adjustment to the opposite side on the rear shocks and see if it’s stiffer or softer. It is not that it is bottoming out on bumps (which of course the rear can at speed with the shortened rear shocks) but I am feeling the roughness of more coarse asphalt and slight porpoising at times on rougher pavement. It’s all slight, but wondered if that is how all bikes feel on rough pavement, or if that’s how they all feel when you lower them, or do I need to do some tuning. I didn’t ride it enough before modifying it to have a mental comparison.
WintrSol
« Reply #9 on: July 16, 2023, 10:40:05 AM » |
If the spacing between the bumps nearly matches the wheelbase, with one wheel is up and the other down at the same time, then, yes, porpoising would be an issue. If the bumps are kind of random, then you have a mismatch in spring rates. I can't tell from that photo, but it kind of looks like there is a pre-load adjustment. Adjusting that, up or down in steps, can often make a better match. It's harder to do in the forks, but possible.
« Reply #10 on: July 16, 2023, 02:54:54 PM » |
I don't believe I read anywhere where you loosened/tightened the springs on the rear shocks, only that you changed them out?
High Desert
« Reply #11 on: July 16, 2023, 02:57:26 PM » |
So I had max preload on. The more I soften the preloading, the easier it is for 98Valk’s fender-bumping-cross-member to happen. So looks like longer shocks is the answer. I may put the stock ones back on and see how it rides, but I sure like the lower stance. I might split the difference.
« Reply #12 on: July 16, 2023, 03:21:37 PM » |
smaller diameter tire is an option for more clearance.
