February 11, 2026, 04:55:06 PM *
Author Topic: Belly tank dimensions/pictures?  (Read 2188 times)
CamTom12
VA
« on: July 18, 2023, 08:57:14 PM »
Since it appears the company that made them is out of business and I can’t find a used one, can anyone that owns a belly tank get me some dimensions and pictures?
I might be needing to recreate a belly tank for a fuel injection project I’m planning.
Foozle
Lexington, KY, USA
« Reply #1 on: July 19, 2023, 07:34:14 AM »
You should touch base with VRCC member Jerry McFarland (Bigwolf).
If memory serves, he had expressed prior interest in doing something very similar.
Jerry's a good guy - and very knowledgeable re: machining, fabrication, etc.
Terry
CamTom12
VA
« Reply #2 on: July 19, 2023, 03:48:06 PM »
Terry
Will do, thanks!
Dusty
Mill Bay B.C.
« Reply #3 on: July 19, 2023, 08:49:48 PM »
 A picture I saw of the tank. I was searching for info  for a tourer I am working on that has a belly tank installed.
https://thehondavalkyriepages2.blogspot.com/2014/12/belly-tank.html
 Dusty
« Last Edit: July 19, 2023, 08:52:25 PM by Dusty » Logged
CamTom12
VA
« Reply #4 on: July 20, 2023, 05:01:40 AM »
 Dusty
Thanks! Would you mind taking some pictures of how it’s mounted on that bike?
psckam
Elmira, New York
« Reply #5 on: July 21, 2023, 05:08:32 PM »
the tank mounts via two bolts in the front to sidestand bracket and  two on each side to the muffler hangers.  The only fussy part was when attaching the main line from the belly tank to the main  fuel tank, there isn't a whole lot of room to get it tight. All else was a fairly straight forward setup.
« Last Edit: July 21, 2023, 05:15:23 PM by psckam » Logged
