February 11, 2026, 04:54:56 PM *
Author Topic: Intermittent tach failing on 2001 Standard  (Read 2179 times)
ryord
« on: August 07, 2023, 02:57:25 PM »
Hello, Well I am having an intermittent problem with the Tach not working, its been fine for about the last year or more and for no apparent reason stopped working when I started the bike today. The failure is the tach just does not work, all other functions are working lights etcetera.
I have checked the battery replaced the ICU with a spare checked continuity between ICU and headlight junction to Tach, thought I had the problem solved  but it arose again today.
Thanks for your help. Rick
« Reply #1 on: August 07, 2023, 03:26:47 PM »
Which model?
Aren't IS digital, and the others are mechanical. Either a dry or broken cable.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: August 07, 2023, 03:30:50 PM »
Check your taillight.
« Reply #3 on: August 07, 2023, 03:43:06 PM »
The tach failing can be a sign of a blown fuse or a sign that the alternator is not putting out.
Grey wolf oz
« Reply #4 on: August 07, 2023, 05:46:41 PM »
In a similar rabbit hole,
The service manual is probably digitally on this forum some where,
Paper copy page 342 tach service for interstate
Page 337 for other models
Both are ignition control module based tacos
Trouble shooting directs you to check peak voltage, and wiring harness for shorts, then ICM ,,,,,,,
Good luck Cheesy
« Reply #5 on: August 07, 2023, 06:21:15 PM »
Valkyrie Norway seems to be gone, and the online archive doesn't allow download of the manual. I don't know anything else but direct email/file transfer. I love the PDF file, for travelling/laptop/tablet, and the hard copy to just thumb through.
Grey wolf oz
« Reply #6 on: August 07, 2023, 06:43:15 PM »
Picked mine up off EBAy
Paper manual for me always Cheesy
ryord
« Reply #7 on: August 07, 2023, 09:03:45 PM »
 The Bike is a 2001 Standard with just the 2 mounted instruments, The Speedometer is mechanical run by cable from front wheel, The Tachometer is electrical.
Jims99
Ormond Beach Fl.
« Reply #8 on: August 08, 2023, 04:21:39 AM »
My tourer is having the same issue, but my headlight is also going out. My problem is in the ignition switch. Contacts need cleaning. If I wiggle the key on and off a few times is stays on. Just haven’t pulled switch apart to clean yet.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #9 on: August 08, 2023, 03:52:04 PM »
Stupid me, I was thinking speedometer the whole time. But I was thinking about the failing alt too as being a Tac issue, not that I've even encountered it personally.
Bagger John - #3785
« Reply #10 on: August 10, 2023, 08:34:18 AM »
I just tested and verified this link: https://web.archive.org/web/20160402032512/http://valkyrienorway.com/1520manual/valkyriegl1500.zip
Bagger John - #3785
« Reply #11 on: August 10, 2023, 08:35:20 AM »
Check the tach and coil grounds.
I've seen problems with these before.
