February 11, 2026, 09:43:57 PM *
Author Topic: New Flashing LED Brake light bulb  (Read 3844 times)
« on: August 23, 2023, 04:59:48 PM »
this is brighter than the LED bulb it replaces and then much brighter when brakes are applied.
flashes three times just as bright and then stays on steady.
iBrightstar Newest 9-30V Flashing Strobe Blinking Brake Lights 1157 2057 2357 7528 BAY15D LED Bulbs with Projector Replacement for Tail Brake Stop Lights, Brilliant Red
https://www.amazon.com/dp/B07LG2DWC3?psc=1&ref=ppx_yo2ov_dt_b_product_details
2 pack 12.35
« Reply #1 on: August 23, 2023, 09:42:16 PM »
I've been using similar bulbs for years in the Interstate, since getting rear ended and losing the BonS lights.
Replaced with them in the trunk and fender brake bulbs.  They're bright, and all three bulbs flash simultaneously.  Definitely gets your attention!
da prez
Wilmot Wi
« Reply #2 on: August 24, 2023, 10:15:31 AM »
Is it a plug and play. Im to lazy to read the info.
             da prez
« Reply #3 on: August 24, 2023, 11:54:29 AM »
Is it a plug and play. ...
The ad says they are.
Timbo1
Tulsa, Ok.
« Reply #4 on: August 24, 2023, 11:57:29 AM »
Mind posting what brand you've had good success with?  I bought some Brishine that I was happy with initially but failed within a year so I went back to stock.
« Reply #5 on: August 24, 2023, 12:12:24 PM »
             da prez
yes common 1157 bulb base same as the brake light socket.
DragonRdr
Gardner, MA
« Reply #6 on: August 24, 2023, 01:04:01 PM »
Anyone actually use them on an Interstate? I took my brake light bulb out and it doesn't have the 1157 metal base, the picture looks like 1157 bulb socket even though Amazon says they should fit? Mine look like the 7443 bulbs.
« Last Edit: August 24, 2023, 01:28:43 PM by DragonRdr » Logged
2000 Valkyrie Interstate
1994 Goldwing Interstate
« Reply #7 on: August 24, 2023, 06:13:44 PM »
You are correct.  If the Interstate brake lights you are using are in the trunk these don't fit.
P.S.  Unless you have previously converted them to 1157.
« Last Edit: August 24, 2023, 06:16:29 PM by Willow » Logged
DragonRdr
Gardner, MA
« Reply #8 on: August 25, 2023, 07:58:53 AM »
Thanks that's what I thought  cooldude
« Reply #9 on: August 25, 2023, 03:28:43 PM »
This is correct, but  similar LED bulbs are made with the"flash and hold" feature that replace the trunk's brake bulbs.  I know because I installed them in my trunk.  They flash a synchronized five times each, then hold.
ridingron
Orlando
« Reply #10 on: August 25, 2023, 08:13:42 PM »
If you click on the link to the site, you have choices.
7443 is one of choices.
DragonRdr
Gardner, MA
« Reply #11 on: August 26, 2023, 04:24:26 AM »
I just ordered the 7443. For that price why not give them a try.  Also, anyone find a replacement LED for the inner tail light bulb on the Interstate? I've searched Google and Amazon and can't find one. I figured I might as well change all the bulbs to LED if I can. cooldude
« Last Edit: August 26, 2023, 07:03:29 AM by DragonRdr » Logged
DragonRdr
Gardner, MA
« Reply #12 on: August 28, 2023, 07:46:07 AM »
I got my new LED brake light bulbs yesterday and installed them. All I can say is I wish I had done it a sooner. It took me less than 15 minutes to swap them out. They are at least 3 times brighter than the old bulbs. I also love the three flash feature. I guess only time will tell how long they'll last.  cooldude
« Reply #13 on: August 28, 2023, 08:08:03 AM »
longrider
Vernon, B.C. Canada
« Reply #14 on: August 30, 2023, 05:40:17 AM »
If I use these in my signals will I need to change the flasher unit?
https://www.amazon.ca/dp/B0739RCR3J/?coliid=I27NGEN0VFXNFM&colid=3VWHA6P6XEMFR&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
Pluggy
NC
« Reply #15 on: August 30, 2023, 06:10:42 AM »
Yes.  An electronic relay should make the LED bulbs flash at the correct rate.  I got a 3 pin LED flasher from Amazon.  (Not sure what is available on Canada Amazon.)
https://www.amazon.com/MFC-PRO-Electronic-problems-FLR-MFC2/dp/B082X6DX6L/ref=sr_1_6?crid=72MZJRMDMS8I&keywords=3%2Bwire%2Bled%2Bmotorcycle%2Bflasher&qid=1693401352&sprefix=3%2Bwire%2Bled%2Bmotorcycle%2Bflaher%2Caps%2C152&sr=8-6&th=1
And, a standard or tourer will need the "non-polar" T5 LED for the turn indicator in the bucket.  eBay has them.  Or you can splice wires and solder in diodes. :'(
« Last Edit: August 30, 2023, 06:17:26 AM by Pluggy » Logged
« Reply #16 on: August 30, 2023, 11:58:12 AM »
Love 'em too.  It was actually a blessing in disguise that I couldn't find replacement BonS trunk lights.  These are equally bright, plus they have the added safety of flashing thrice before holding steady.  You're right, mine flash three times and hold, not five times.  With a relay my trunk and fender brake lights all flash in sync.  Hopefully no more getting rear ended for me.
Slyk Willy
Michigan
« Reply #17 on: August 31, 2023, 11:28:09 AM »
I was pulled over by a LEO for having flashing brake lights here in Michigan. I did however swap my OEM with Sylvania "Super Bright" from auto parts place. Way brighter. They do say "off road use only", so don't tell anyone.
Slyk Willy VRCC # 16194
« Reply #18 on: September 01, 2023, 08:01:47 AM »
Wow, I would think that's pretty rare since flashing LED brake lights are pretty common on motorcycles.  Maybe the officer just wanted to make sure you weren't a hellion.  As far as the off road use disclaimer, I'd rather someone have to squint for a second than not notice my brakes at all.
« Reply #19 on: September 01, 2023, 08:29:11 AM »
what I have found is that a constant flashing red-light is a no-no.
every State motorcycle handbook directs rider to flash brake light on/off a few times when braking to alert driver behind for safety.
some states have laws allowing brake light to auto flash 4 or less times and then steady on.  many states have zero laws about that.
Slyk Willy
Michigan
« Reply #20 on: September 03, 2023, 10:00:01 AM »
I'm sure the LEO was trying to make a statement. He was young. I did research on the law and yup, it's right there, flashing is a nope. I left the lights but turned off the flash.
-mike-
Germany
« Reply #21 on: September 06, 2023, 12:59:02 PM »
These bulbs aren't available over here.
I had to order overseas.
Worth every penny:
https://youtube.com/shorts/qytjXtqONWc
Thanks for posting it.
-mike-
« Last Edit: September 06, 2023, 01:01:27 PM by -mike- » Logged
Glaserbeam
Southern California
« Reply #22 on: October 08, 2023, 11:06:31 PM »
Hey, 98Valk, thanks for the tip!  I used HyperLites on my old CBX, but didn't want to go through the hassle of wiring it into the Valk, so I bought the iBrightStar bulbs you recommended.  The ones they sent me didn't blink, so I returned them, but it was a blessing in disguise:  I ordered these for $10, and it works great - I even ordered a pair for my Toyota truck:
https://www.amazon.com/dp/B0BJ71G6BL?psc=1&ref=ppx_yo2ov_dt_b_product_details
« Reply #23 on: October 09, 2023, 05:26:18 AM »
yep the Lord always blesses His true followers.  angel
looks like same bulbs for lower $$. The ones I bought were same price and then slowly kept going up in price. That's amazon.
longrider
Vernon, B.C. Canada
« Reply #24 on: October 09, 2023, 07:53:44 AM »
I ordered and received a set of bulbs from the original post at the top of this thread.  I have returned them.  The brake led was on all of the time as a tail light.  When the brake light was energized all it would do was constantly flash the same leds.  I have added the last link to my wish list and may give it a try.
