February 11, 2026, 03:15:58 PM *
Author Topic: Clutch  (Read 2131 times)
Devinci40
« on: August 28, 2023, 05:37:10 AM »
My clutch lever has no pressure, if it had a cable it would feel like a broken cable that’s what it feels like. Any ideas on what it might be? Thank you
« Reply #1 on: August 28, 2023, 06:00:51 AM »
If you didn't do anything to your bike or clutch and this condition
came on real quick, it would be good to look up under your engine
where all the kickstand stuff is bolted on. If your clutch slave cylinder
let loose, there'll be a mess down there...
jnicks01
Clinton, IN
« Reply #2 on: August 28, 2023, 06:12:16 AM »
Try bleeding it first.  Make sure there are no air bubbles.  Might take a while to get pressure.  And as others mentioned. Look for leaking from slave cylinder.
I want to scoop out your brains and eat your knowledge.
RonW
Newport Beach
« Reply #3 on: August 28, 2023, 07:03:00 AM »
The clutch slave has passages for fluid to weep out. Should leave a visible trail.  It's way in there though.
2000 Valkyrie Tourer
« Reply #4 on: August 28, 2023, 12:23:49 PM »
First things first, did you check that the master (I hope I can use that racist term here) cylinder reservoir is full?
« Reply #5 on: August 28, 2023, 04:04:06 PM »
I don’t really understand why. So I have no explanation but two Valkyries I help basically with rear wheel R/R for no apparent reason list all hydraulic fluid in the clutch. We had to back fill and bleed and all went back to normal. The initial symptom was as you described.
