July 12, 2025, 08:29:22 AM
Ram mounts for handlebar clamps
Topic: Ram mounts for handlebar clamps (Read 1701 times)
cutter
Plantersville, Texas
February 03, 2010, 07:55:50 AM »
Came in yesterday and installed it. I like it!
I have an I/S and doesn't interfear with the visability of the dash. Got the ball, the B size arm and a craddle for the unit. If your looking for one, I would recomend this. Hmmmm, now I just need to figure out where to put the power supply for this thing.
here is the link
http://www.ram-mount.com/NewProducts/MotorcycleClampMount/tabid/2038/Default.aspx
rangernight
New Orleans, LA
Re: Ram mounts for handlebar clamps
February 03, 2010, 08:48:44 AM »
I installed my power supply by useing 2 power ports (one on each side) in the speaker housings. I used the marine applications that have rubber caps to keep water out when not in use. Drilling the 7/8" hole was painfull however once installed it gave me power for my XM, GPS and radar detector.
Ran one hot wire from battery (with 20amp fuse) and it has servived for 8 years now.
asfltdncr
February 03, 2010, 09:59:20 AM »
Quote from: cutter on February 03, 2010, 07:55:50 AM
here is the link
You might consider something other than the 12volt cigarette lighter and look at sockets that perform better, smaller, and easier to use.But...you need to think through what you have, what you are going to have (heated gear, battery trickle charger, etc.)
cutter
February 03, 2010, 11:26:39 AM »
All ready set up for gerbing electrics. Not sure what other sockets are available and haven't looked.
As for mounting in the fairing/speaker housing, what area works best for ease of pluging in and yet out of the way?
Kingbee
VRCC# 576
Northern Illinois
February 03, 2010, 05:03:33 PM »
I mounted my power supplies under the speaker panel, plugged into cheap cigarette lighter sockets. If you want to move your accessory between vehicles, you could buy a cheap replacement power supply on e-bay.
PIC is supplies for XM radio & GPS.
1999 Interstate
2000 Interstate
2004 Rune
Madmike
Campbell River BC, Canada
February 04, 2010, 07:20:47 PM »
http://www.cyclegadgets.com/Products/product.asp?Item=PLUG
http://www.manicsalamander.com/mounted_connector.htm
http://www.electricalconnection.com/
Hereb are a few links, the SAE 2 wire connectors are nice.
=> InZane XXV
