November 11, 2025, 09:31:55 AM *
Author Topic: Fluid on my tyre :O  (Read 2597 times)
Grey wolf oz
« on: October 01, 2023, 01:39:23 AM »
Hello team
Pulled up for some gas today,
10 bucks a gallon here in australia :0
There was a little fluid on my tyre as i checked the air pressure,
Dang nabit if pooped a break calliper seal
I’m a bit time poor,,
Has anyone got a set of front calliper in reasonable condition or rebuilt for sale
Gonna have to rebuild otherwise
Cheers team
Luke
RonW
Newport Beach
« Reply #1 on: October 01, 2023, 02:36:34 AM »
Always facinated with the way aussies describe things. Reminds me of an aussie I met who caught a roomate in a hostel stealing from his backpack, "So, I grabbed him by his neck and started to strangle the blok." I think it was 'blok.' $10 a gallon!!
Anyways, it's probably just as fast to replace the seals. Since you still gotta remove the calipers and refilling the fluid into empty brake lines takes the most time.
2000 Valkyrie Tourer
Grey wolf oz
« Reply #2 on: October 01, 2023, 03:57:25 AM »
True,,  i had to vacuum bleed this set last time i did brakes !!
I need a cylinder extraction tool right ?
« Reply #3 on: October 01, 2023, 04:40:37 AM »
you sure its not fork fluid and indeed brake fluid? fork seals leaking is much more common.
RonW
Newport Beach
« Reply #4 on: October 01, 2023, 04:59:49 AM »
Not necessarily. Er, hydraulic pressure should pop the piston across the room. A leaky seal might reduce that though. Anyways, you're dealing with a leaky seal not of a stuck piston.
Still, place something like a paint stick to stop the piston's trajectory. Both pistons must extend out as much as they're needed to in unison, that is, if you remove only one piston out of its bore, you won't thereon be able to remove the stubborn piston by squeezing the brake lever because hydraulic pressure will escape through the empty bore of the removed piston.
Of course avoid dinging the piston's surface by using a file to clean off the grit (jokingly). I suggest at least 2 cans of brake cleaner to get rid of every last speck of grit before reassembly.
RonW
Newport Beach
« Reply #5 on: October 01, 2023, 08:22:34 AM »
Luke, was as it fork fluid?? 98valk has a point.
WintrSol
Florissant, MO
« Reply #6 on: October 01, 2023, 11:17:43 AM »
Easy test for fork oil vs. brake fluid - smell it. They are VERY different.
Grey wolf oz
« Reply #7 on: October 02, 2023, 01:40:39 AM »
It’s brake,,,,,,,,,    Master cylinder is draining through the calliper
Grey wolf oz
« Reply #8 on: October 02, 2023, 01:42:01 AM »
File ??
Why not a 9” grinder ?
Grey wolf oz
« Reply #9 on: October 02, 2023, 01:43:28 AM »
Very squishy brakes and empty master cylinder res,,,,,,,,
RonW
Newport Beach
« Reply #10 on: October 02, 2023, 02:39:36 AM »
When replacing brake pads, 'some' people push the pistons back in their bores without polishing them pistons and the grit damages the seals in the process. The pistons are pushed back to make room for new thicker brake pads. A few minutes spent shoe shinning the pistons woulda saved hours. This has never happened to me but only because on my very first brake pad replacement an unheralded technician brought over a can of brake cleaner and told me to buy it and of he's not cleaning the piston that caused his brakes to leak.
Grey wolf oz
« Reply #11 on: October 08, 2023, 01:06:58 AM »
JOB DONE,,
The first calliper took longer, and hells it takes ages to bleed these
Any one ever heard of a thing called a speed bleeder ?
Valve I believe
Cheers
Luke
« Reply #12 on: October 08, 2023, 05:00:11 AM »
I have used and liked speed bleeders for years. There's a particular size for the brakes
and a longer one that works for the clutch. Here's an article by someone else who
likes them and besides all his gushing about them, he includes the part numbers
for both sizes needed for the Valkyrie...
https://www.billanddot.com/brake-bleeding.htm
JOB DONE,,
Valve I believe
Cheers
Luke
mello dude
Dayton Ohio
« Reply #13 on: October 08, 2023, 02:29:46 PM »
JOB DONE,,
Valve I believe
Cheers
Luke
http://speedbleeder.com/bikechart.htm
Alternate......
https://www.motionpro.com/product/08-0143
Grey wolf oz
« Reply #14 on: October 11, 2023, 12:51:01 AM »
Thanks mike,
JOB DONE,,
Valve I believe
Cheers
Luke
Grey wolf oz
« Reply #15 on: October 11, 2023, 12:51:41 AM »
JOB DONE,,
Valve I believe
Cheers
Thanks mello!
Luke
Alternate......
