December 28, 2025, 07:30:47 AM
Removing I/S rear rotor
Topic: Removing I/S rear rotor (Read 1993 times)
Whooray
Idaho State Rep
Kuna, Idaho
October 12, 2023, 10:18:44 AM »
I’ve acquired a used rear tire with mounted rotor plate.
I’m trying to remove the rotor and man are bolts really tight.
I’m afraid of them breaking if I apply any more pressure.
Any suggestions on how I might get them out?
Thanks, Raymond
Vietnam Vet 6/68 - 1/70
919th Combat Engineers
11th ACR (Blackhorse)
Re: Removing I/S rear rotor
October 12, 2023, 10:24:33 AM »
Have you tried some heat ? I think they have a fair amount of locktite (or Honda’s version) on them.
da prez
Wilmot Wi
October 12, 2023, 10:25:41 AM »
Use a blunt center punch that fits in the allen socket. Hit it hard and do all of them. A hand impact driver will also help. Do not be bashful. Use the correct size allen socket.
da prez
RonW
Newport Beach
October 12, 2023, 10:36:23 AM »
Are you able to reuse the same bolts?
2000 Valkyrie Tourer
Whooray
Idaho State Rep
Kuna, Idaho
October 12, 2023, 10:46:15 AM »
[quote
I want to be able to reuse the bolts .
I’m going out to try rhe suggestions now.
October 12, 2023, 10:55:12 AM »
Are you using a breaker bar or just a ratchet handle? If the latter get a breaker bar at it should come right loose.
Whooray
Idaho State Rep
Kuna, Idaho
Reply #6 on:
October 12, 2023, 11:02:18 AM »
Da Prez! You da man. Used a blunt end punch with small ball pen hammer… wasn’t bashful ….but not super aggressive. Broke ‘em loose and pulled them out.
Thank you all for great “fix it” ideas. Raymond
Reply #7 on:
October 12, 2023, 01:56:10 PM »
Quote from: Whooray on October 12, 2023, 10:46:15 AM
[quote
yes can be re-used, torqued correctly and with high temp medium thread lock. Honda's high temp medium thread lock is red in color. Hondalock 2 HT - Medium Strength High-Temp Threadlock
https://jhpusa.com/products/honda-hondalock-threadlock
if u use common red thread locker which isn't high temp or medium strength u will need heat to remove the bolts.
=> InZane XXV
