Ok, so this has been something that's been kinda bugging me lately... I drained my carbs, and filled my tank (with stabil) for the long MN winter... I'm sure I'm overthinking this, but how do you refill the carbs come springtime. I'm going to be taking the tank off to drain it, so do I get a funnel and fill the bowls with the tank off?? It's my first winter with the lady...
You are like my brother, you worry too firkin much.....
Make sure the battery is FULLY charged. Don't ask why, don't have time to go into why here now.
turn the fuel valve on
Pull the choke ALL THE WAY on. hit resistance, push it some more
hit the starter button.
after about 20 seconds, if it hasn't started. let the starter cool off for a few minutes, less than 4.
hit the starter again, it should fire this trip. when it does fire on 1 cylinder, keep on the starter button a little longer. OH, keep your fingers off the throttle until ya get the choke off. You go to blip it and she will die.
If it doesn't start, wait the 20 seconds again, and then go for it till it his running. gradually turn the choke off. Turn it off too quick she will die and you will have to choke and restart.
Same way you would do it if she runs out of gas on ya.............. Only on the run out of gas, take it off of reserve before you will away.... If ya don't, you will be walking for gas...................
