December 28, 2025, 07:31:06 AM *
Author Topic: Intersate rear speakers  (Read 2358 times)
Joe333x
Boston
« on: November 11, 2023, 10:53:26 PM »
Searching the forums I've found a bunch of information but unfortunately all with dead links. I know I have no rear speakers, I know I can add them. It seems that no rear harness exists anymore, I cant even find a photo of one. I don't mind splicing in the wires but I don't know where the harness connected to. I seen on posts that said it was a white connector with four pins but I do not have that on mine. The only open connections I have are the aux and two big 9 pin connections, I'm just guessing but maybe one is for the rear speakers and one is for a CB? I want to replace the fronts with polks and add polks to the rear as well.
« Last Edit: November 12, 2023, 10:37:21 AM by Joe333x » Logged
Joe333x
Boston
« Reply #1 on: November 12, 2023, 10:37:06 AM »
Okay with some further investigation I found the rear speaker connector completed covered in grease. Cleaned it up and now to see if I can find a connector if not I can just tap it. photos of the connector incase it comes up in a search for someone. its a 4 pin with Blue/Yellow Grey/White Brown/white and red/yellow
https://photos.app.goo.gl/cHncUj6vQ9VrEBtS9
fgtex
« Reply #2 on: November 13, 2023, 06:21:48 PM »
You may be able to find the connector at Cycle Terminal .com .  I ordered, but have not received, a connector to add a rear brake light to my Interstate.
Maybe PN SC1104 to connect to the main harness at the side cover.
Wiring diagram on this site (you may already have it): http://www.valkyrieriders.com/shoptalk/GL1500-CF%20OEM%20Rattlebar%20Schematic%20Colorized.pdf
« Last Edit: November 13, 2023, 06:30:37 PM by fgtex » Logged
2000 Honda Valkyrie Interstate , 2022 Honda CRF300L Rally
Joe333x
Boston
« Reply #3 on: November 13, 2023, 06:42:30 PM »
Update: The 01-05 GL1800 harness does fit!
After more research someone on Facebook said that they used the 01-05 GL1800 harness and it works so I ordered one. I will report back if it works.
https://electricalconnection.com/index.php/product/honda-gl1800-rear-speaker-harness/
« Last Edit: November 16, 2023, 08:45:39 PM by Joe333x » Logged
