March 14, 2026, 03:47:19 AM *
Author Topic: Lowrance iWAY  (Read 4143 times)
godfire
Republic of Texas
« on: April 18, 2008, 11:10:28 AM »
Anyone get there iWay mounted. If so how is it working out. My girlfriend is using mine in her cage, but I'm thinking it's time to get it mounted to the bike.
Ride Safe
Ride Often
Six Guns
Fort Worth, Texas
« Reply #1 on: April 18, 2008, 01:29:42 PM »
I believe Patron has his IWAY 600 mounted and has had good things to say about it. I still have mine, new in the box and need to install it. Good luck with your installation. If I didn't work so much maybe we could get together and help each other out.
SideCar
Bikers don't need shrinks!
Colleyville, TX
« Reply #2 on: April 18, 2008, 02:52:32 PM »
Yep, Patron has his mounted. You sure have to use a sturdy mount since those things weigh so much. Dang, I have no idea what they were thinking on the weight.  I mount mine with a short ram mount, but even that gets some wobble because of the weight.  Can't remember how Patron had his mounted.
Patron
« Reply #3 on: April 19, 2008, 04:38:39 AM »
Yep, I have a Iway 600 mounted on my wing.  Actually it would be much easier to mount on a valk than a wing because of the funky handlebars on the wing.  My wing mount has a handlebar ram mount and I use a short arm to connect it to a Ram quick connect adapter screwed onto the Iway.  Even with the weight of the Iway, which is substantial, I get very little vibration.  I love the Iway because of its functionality, ease of use, and screen size.  Probably the screen size is the best part.  You can get the ram quick connect and hard wire cord at www.Lei-extras.com.  The hard wire cable is listed under the Iway 500 but it is exactly the same cord you need for the Iway 600.
Good luck with the install.
