November 20, 2025, 09:05:24 PM *
Author Topic: Swing Arm Lock Nut Wrench  (Read 2325 times)
Grumpy
Tampa, Fl
« on: February 05, 2010, 05:49:27 PM »
I need a Swing Arm Lock Nut Wrench, any one know where I can purchase one, or beg or borrow one ?
« Reply #1 on: February 05, 2010, 06:04:26 PM »
Have you tried Hal at HDL?  If not you will have to call to locate the wrench.
I don't have the # handy as I'm not at home.  Won't be there till 9:00 AM or after. Got to get 2 signatures first.
Do you know LaMonster, VRCC # 1?
Lives in TN now, he has one.
Other wise, Good luck.   Not to much of a call for them.
« Last Edit: February 05, 2010, 06:09:26 PM by R J » Logged
Grumpy
Tampa, Fl
« Reply #2 on: February 05, 2010, 06:41:39 PM »
I will try HDL tomorrow, thanks.....
Friagabi
Tacoma, Wa
« Reply #3 on: February 05, 2010, 06:45:40 PM »
State of Washington, Tacoma. Ride a Red and Black 2KIS I have one with the allen wrench that I made. If you cannot find one closer drop me a e-mail. I grease my swing arm every other year. So I use it every other year.
Grumpy
Tampa, Fl
« Reply #4 on: February 05, 2010, 09:24:12 PM »
Thanks, if I cannot find one locally, I will contact you. I pulled mine down, replaced the bearings, races etc. I have the allen, just cannot tighten the left side lock nut.
« Reply #5 on: February 06, 2010, 06:43:00 AM »
Friend of mine made (welded) a portion of the tool needed, he has long since left the area but I still have it. Gave it to me when he moved. I have to look at it again but I think all it needs is a handle of some sort welded on to it. I think I know where it is in my mess out there.  Cheesy Somewhere in buried in my computer is also a drawing giving dimensions, which might give a clue as to the handle location, size, etc......I'll go hunting in the meantime.
Correction: the handle also needs a square hole in it for the torque wrench.
If you're interested shoot me an email and I'll give you my phone #.
John
« Last Edit: February 06, 2010, 06:56:05 AM by John Schmidt » Logged
quexpress
Montreal, Québec, Canada
« Reply #6 on: February 06, 2010, 07:50:45 AM »
The lock nut wrench is not required.
Torque the middle allen bolt and then mark its position with a felt pen.
Take your modified socket and torque the lock nut.
You will then notice that the middle allen bolt has not moved!  Smiley
Works for many people. Good luck!
I still have a full deck.
I just shuffle slower ...
« Reply #7 on: February 06, 2010, 08:40:30 AM »
I was keeping that a secret. Was hoping to get a free breakfast out of the deal.   Grin
You staying warm up yonder, lots of nasty weather blowing around this year it seems. It all reminds me of the weather when stationed at Loring AFB in the Caribou, Maine region back in the late 50' and early 60's. If we only got 100" of snow it was a light year. So what's the chances you'll make it to Michigan for InZane this year?
Misfit
Colorado Springs Colorado
« Reply #8 on: February 06, 2010, 09:23:09 AM »
I have one that I have lent through the mail several times. A local member has it at the moment. If you don't come up with one soon let me know and I will see that you get it.
Jeff K
« Reply #9 on: February 06, 2010, 11:50:19 AM »
That is the same method I use.  cooldude
quexpress
« Reply #10 on: February 06, 2010, 05:35:06 PM »
LOL! Sorry about that John but, as you know, many from the "old" tech board use that trick.  Cool
Nasty weather is all we get up here!  Undecided
Very slim John. Please let me know if you head up to New England this year.
quexpress
« Reply #11 on: February 06, 2010, 05:36:45 PM »
... and I'm sure that others have been using it also!  Smiley
