February 11, 2026, 03:04:49 PM *
Author Topic: 6 into 6 exhaust question  (Read 1735 times)
Tx Bohemian
Victoria, Tx
« on: January 11, 2024, 06:56:45 AM »
I have the 6 into 6 exhaust on my 99 standard, not sure what brand as they were on the bike when I got it.
They have (had) the half covers on the pipes right out of the heads. They cover the outside of the pipes for about a foot, and each are held on with a couple of little springs.
Am I rite in assuming these are there for cosmetic appearances only?
Mine are all rusted and nasty looking.
I pulled them off, which was not the easiest task I might add!!  Not sure why the springs were there as they were quite tight fitting!
Al
« Reply #1 on: January 11, 2024, 07:19:26 AM »
Appearance yes.
And they are called heat shields (not that I would touch them after the bike is running).
Maybe you only get a 1st degree burn with them and 2d without.   Smiley
How did the pipes look underneath?
« Reply #2 on: January 11, 2024, 07:31:02 AM »
if exhaust outlets are straight they are cobras, turned out tips are Two Brothers.
neither exhausts came with hear shields.
Grey wolf oz
« Reply #3 on: January 11, 2024, 11:45:38 PM »
I’ve cobras on mine, and the heat shields are kinda on with hose clamp sort of deal
Cosmetic only in my opinion
SCain
Rio Rancho, NM
« Reply #4 on: January 12, 2024, 04:54:42 AM »
If I remember right, Rivco made the heat shields for the Cobra 6x6 pipes to cover up the bluing of a single wall pipe.
Steve
Tx Bohemian
Victoria, Tx
« Reply #5 on: January 12, 2024, 05:18:33 AM »
Appearance yes.
Thanks once again guys, Y'all are the greatest!!!
Funny about the 1st or second-degree burns!
The pipes underneath are a bit blued but they look WAY better than the RUSTED-UP shields!!!
However, as we all know, they mostly can't be seen unless you are laying on the ground or have it on a bike lift!
Al
