December 28, 2025, 07:31:05 AM *
Author Topic: rear rotor  (Read 2216 times)
CoreyP
Bluffton, SC
« on: February 16, 2024, 04:21:19 PM »
Went to change my rear tire and surprise apparently my pads gouged my rotor. About 50,000 miles on the bike so I don't know if that is a long time or short time for a Valkyrie rear rotor????
I don't like the price of a Honda rear rotor so has anyone had good luck with after market rotors? If so which ones?
« Reply #1 on: February 16, 2024, 04:57:53 PM »
If you have an Interstate or a newer tour there is a rotor on the classifieds. Staying with OEM is best.
« Reply #2 on: February 16, 2024, 05:32:06 PM »
Short time. I’ve got 150,000 miles on my Interstate, and 60,000 on my Standard. Both original rotors in good shape. Your front brakes contain most of your stopping power. Rears should be used lightly (imho).
« Reply #3 on: February 16, 2024, 06:12:10 PM »
You can clean the rotor up the best you can and keep it.
You may burn through pads a bit quicker, no big deal, but it will still help stop the bike fine. (OE pads too.)
CoreyP
Bluffton, SC
« Reply #4 on: February 16, 2024, 08:01:20 PM »
I have a lip on this rotor. It is defiantly not smooth any more. Can you just run a grinding wheel around it? That doesn't sound like a good idea to me? How would you clean up a rotor????
I know the fronts are what is used the most in stopping the bike. I think i also have a problem with my rear caliper but I just didn't feel like dealing with that tonight. That might need a rebuild?
I rebuilt both front calipers, master cylinder and replaced the pads last year. Rotors on the front are fine. I didn't really think about the rear because it really isn't that important.
BTW my bike is a 2001 standard.
« Reply #5 on: February 17, 2024, 03:51:22 AM »
Lips on the outside edges of my rear rotor too.
More an issue with reassembly with new pads than stopping.
I just used steel wool, no power tools.
I'm no expert.
« Last Edit: March 11, 2024, 11:06:40 AM by Jess from VA » Logged
« Reply #6 on: February 17, 2024, 04:16:36 AM »
'01 has the thickest and heaviest rear rotor of all yrs.   without pics of grooves, don't know how bad they are, however since pads are not attached to the backing plates, any grooves to rotor will not be a problem. Just clean the caliper pistons and make sure they function, and install them with new pads. suggest using DOT 4 LV, which has a higher wet boiling point and provide a firmer feel over a wider range of ambient temps.  It also extends fluid replacement from 2-3 yrs to 3-4 yrs.  not replacing brake fluid causes caliper piston corrosion and failure.
post pics of rotor if u can.
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #7 on: February 17, 2024, 08:32:01 AM »
Not to derail this thread, but I remember a vender at one of the InZanes (possibly as far back one of the Michigan ones) who was turning rotors.  Does anyone know who those guys were or if they still exist?
Maybe those guys at the InZane were a one-off, but it seems that Valkyrie rotors could be turned (once!) and used as long as stay within tolerance.
« Reply #8 on: February 17, 2024, 02:31:29 PM »
     Should use a micrometer and see what the tolerances are for your application. Any good auto machine shop should be able to turn your rotor. RIDE SAFE.
CoreyP
Bluffton, SC
« Reply #9 on: February 21, 2024, 11:00:22 AM »
For anyone interested. The end result is I'm going to rebuild the rear caliper, parts a coming. New brake pads and I'm going to try to sand down the rotor a little bit. The grooves aren't that bad so I'm not all that worried. Parts won't be here till this weekend so I'm calling around today to see if any brake shops will turn motorcycle rotors. If someone can do the rotor I will do that but I don't live in a place with a machine shop anywhere. Tire and brake places yes but I bet they don't do rotors any more. Just sell new ones.
« Reply #10 on: February 23, 2024, 07:20:33 AM »
I would follow the advice given of scuff or sand rotor lightly and install new pads.
Keep a eye on them for the first couple of rides, then forget it.
Just under $23.00 per set, pads are cheap. Rotors are not.
Pluggy
Vass, NC
« Reply #11 on: February 23, 2024, 07:31:43 AM »
Good pads for $23?  Share the source.  What I see is either OEM expensive or too cheap to consider.  A lot of us would be interested in a quality item at a reasonable price.
« Reply #12 on: February 23, 2024, 09:15:56 AM »
https://www.rockymountainatvmc.com/oem-schematic/35
Rear Brake Caliper
#1
Pluggy
Vass, NC
« Reply #13 on: February 23, 2024, 09:46:43 AM »
This is to put Interstate rear pads on the front and rear of any Valkyrie?  (The link didn't work on my computer.)
Pluggy
« Last Edit: February 23, 2024, 09:57:17 AM by Pluggy » Logged
« Reply #14 on: February 23, 2024, 09:50:28 AM »
Sorry, on my computer that link does not lead to $23 brake pads.  Can you tell us what they are?  Rocky Mountain does sell OEM pads at $53.64 a pair.
Pluggy
He is referring to the rear pads.
1   06435-MBY-671   PAD SET, RR.   $27.72   $22.73   4 In-Stock
Edit; I just noticed the Standard pads are listed at $53, and the Interstates are at $23. I’m not sure why, I believe they are the same.
« Last Edit: February 23, 2024, 09:57:24 AM by The emperor has no clothes » Logged
« Reply #15 on: February 23, 2024, 10:04:21 AM »
Pluggy
I’m pretty sure I’ve used the same pads for Standards and Interstates. Although I haven’t used the rears up front.
I know a lot of guys poo-poo it, but I’ve been using aftermarket ones like these for years with no problems.
https://www.amazon.com/GL1500CF-Valkyrie-Interstate-1999-2003-KVTR-15022/dp/B0C5W3XXHC/ref=sr_1_10?crid=PVNVR99B7N92&dib=eyJ2IjoiMSJ9.Hr1MC3f0qGCmqvHY1wn471y7mkm-5rhU4WlaGcufuaC8FtAgV6SKk1EI_gJv_Ks0NXNgkqUiAyeGkk7pu2UoXdQquPp1KBGUHWHx9rqTdVVPgIf-HKpcpgqYCo5ylX8B2jxgvs429jfJHlC6IEKOqtxP14DxSfFWppVDsiKZl53gahxrjqKIzmwtzpNnrfNAzhx3B4XZrotAzre_nOu21KIsjZWV08qxDTxQi3WDsyKsdlRGoKOr64l4J46M_z8ONrYVIQjXYoqujK0WxVjckr2asDov6071-8BqaMlQISk.HB4aerV7OpvoMDrfZqm64lzBfOITfgEzlCUjAf8VebM&dib_tag=se&keywords=2000+honda+valkyrie+brake+pads&qid=1708711263&sprefix=Brake+pads+Honda+val%2Caps%2C157&sr=8-10
« Reply #16 on: February 28, 2024, 04:36:06 AM »
Interstate rear pads may be so low in cost because they are still original inventory and never re manufactured.
IDK, but my experience is with modification the IS rears pads work in all Valkyrie calipers.
Pluggy
« Reply #17 on: March 11, 2024, 10:19:04 AM »
Most automotive parts places cannot turn a motorcycle rotor.  The issue is that the MC rotor's center hole is way to big to fit into a standard turning machine.  HotGlue made an adapter to bolt to the rotor that has about a 2.5" hole in the middle. This allowed the machine to be able to clamp the adapter in the machine and rotate the machine slowly to tap the rotor in line.  Then, just finish tightening the bolts and turn the rotor just like a car/truck.
HotGlue (Mark Baker) makes things like this all of the time.  Just sayin'.
Hay  Cool
