« on: February 19, 2024, 05:54:26 PM » |
Just to change things up (and avoid current events), lets talk about tools (equipment, gear, kitchen, yard, you get the idea). My Amazon bench grinder came today (my old one died last year). DeWalt 6"; Grinding wheels course and fine, buff wheels, wire wheels). It's mostly used to clean up many of your other tools and equipment (or rusty nuts). I use the grind wheels once in a while, but otherwise keep it loaded with a stiff wire wheel on one side and a hard cotton buff on the other (with various polish compounds). They get used all the time. I have a small shed workbench, but won't give up the work space. So I bolt it to a short sturdy stool with rubber feet, and can move it anywhere I want to use it. It's better throwing sparks outdoors than in my sheds with the gasoline and flammables. Portable, I can work sitting, kneeling or standing. Before removing the grind wheels to stick on the wire and buffs, I used the fine grind wheel to sharpen up some loppers, clippers, hedgers, axe, adze, hatchet, machete, shovels, and anything else I could find that could use an edge.  So probably, given my previous history, in the near future, I will be known as 3 finger Jess. DEWALT Bench Grinder, 6 Inch, 3/4 HP, 3,600 RPM For Larger Grinding Applications (DW756) https://www.dewalt.com/product/dw756/6-150mm-bench-grinder So what stuff (tool) do you have?
« Last Edit: February 19, 2024, 06:01:10 PM by Jess from VA »
« Reply #1 on: February 19, 2024, 06:36:22 PM » |
Jess. I bought a no name grinder just like yours. I bolted it to a piece of plywood for the same reason you used the stool. I also have a big boy grinder that I use more. I really bought the portable to sharpen knives and axes and things. I have wheels made from MDF imbedded with rubbing compound Ave I use it backwards to sharpen. It’s a whole thing. But it works well
RP#62
« Reply #2 on: February 19, 2024, 06:44:32 PM » |
I've found that if you put a wire wheel on it, it does an outstanding job of removing fingerprints (from your fingers). Its also great for snatching things out of your hands and slinging them across the shop.
-RP
« Reply #3 on: February 19, 2024, 06:58:35 PM » |
-RP
Escaping wire also make for deadly projectiles.
Savago
« Reply #4 on: February 19, 2024, 07:16:58 PM » |
Not on the same price scale, but I bought a kit of stainless steel tweezers from Amazon that were a life saver when the key of my ST1300 decided to break *inside* of the gas tank lid: https://www.amazon.com/dp/B09J97YT3X?asc_source=01HDRG07ZP5FJRJVES5GYSHWKK&tag=snx1-20&th=1The model with a 'eagle beak' curved shape worked perfectly to grip the broken key *inside* of the tumbler and allowed me to extract it. That would be the SA-15 of the set, can be purchased separately for $5.99, I think I will buy a spare and carry it with my small bag of tools with the bike just in case.
« Reply #7 on: February 19, 2024, 07:55:47 PM » |
All mounted to the work bench. A 4" wide bench vise that gets used a Lot-3d hand if you will. A bench grinder from H/F that currently has a coarse wire wheel and a coarse grinding wheel mounted. A small drill press-nothing fancy BUT gits the job done. Also have a 4" hand held grinder with various cut off wheels and a selection of wire brushes. Have a medium sized roll away tool chest with the various hand tools. And I've lost track of the ends and odds scattered around the shop BUT as we all KNOW throw something away and the next day or 2 the thing you threw away is now NEEDED!  Tried sortin the nuts bolts screws waskers and nail boxes but when you Actually Find WHAT you need and do NOT have to make a trip to the hardware store or the auto parts store or wally wurld we all Know hat That Feels!  Sides I Know where most everything is so Tat makes me happy! RIDE SAFE.
« Reply #8 on: February 20, 2024, 03:57:23 AM » |
Nice fine there.  also notice I don't see JIS mentioned anywhere in that listing. actually there is only one company that is making pure JIS screwdrivers. All others are using the new std, even Harbor Freight phillips screwdrivers work excellent in JIS screws. ""Most JIS advertised screwdrivers sold today by companies like Vessel, Hozan, and others are actually conforming to a new standard: DIN 5260 which is identical (at the tip) to the newer ISO 8764-1."" https://rtstools.com/jis-vs-phillips-screwdrivers-and-where-to-buy-a-jis-screwdriver/
« Last Edit: February 20, 2024, 04:03:23 AM by 98valk »
NewValker
VRCC# 36356
Oxford, MA
« Reply #9 on: February 20, 2024, 03:58:04 AM » |
Good, a tool thread just in time….. Since I moved into an apartment, and have the bikes in a container, I no longer have a compressor. Looking for recommendations for a small compressor to air up tires, blow out the chainsaw etc. I have 110 power in the container, debating over a pancake oil-less or Milwaukee has a rechargeable compressor. Honestly it might get used 6-8 times a year. Thanks for any info.
Craig
Turns out not what or where, but who you ride with really matters
mbramley
« Reply #10 on: February 20, 2024, 04:41:27 AM » |
I just bought one of those recently-I love it. I have used check valves of different styles and sizes over the years but that little one does a better job than any of them. I still had to use a vacuum pump when I flushed my clutch line to get the master cylinder primed but it did a great job bleeding both the clutch and brakes.
h13man
Indiana NW Central Flatlands
« Reply #11 on: February 20, 2024, 05:04:40 AM » |
Difference between a 8" and 6" dia. grinder is night day difference in "handling" while using and more torque. I had a 8" Wilton but someone made me a offer I couldn't refuse as I revised it to use a diamond wheel for carbide tool sharpening. Have a 6" now for 15 yrs. but if come across a 8" in my weekly shopping at sales.....
« Reply #12 on: February 20, 2024, 05:18:47 AM » |
I wouldn't call DeWalt a no-name brand. This one is heavier than my last, and the bearings very smooth and when turned off, it spins and spools down for a long time before stopping. I have also lost fingerprints and had things grabbed out of my hands with a bench grinder. But I've never had any wires exit any wire wheel. Of course I always wear good eye protection when using it. And I've also taken to wearing semi-disposable gloves (thin weave with latex palms and fingers) for most all outdoor work, since I have a tendency to nick up my hands. You can easily pick up a dime wearing them. They're hardly warm, but they're warmer than no gloves at all. A 10 pack may last a year.  Savago, I like those tweezers.  I get the occasional splinters that are difficult to remove with my old bathroom beaters. I'm going to order a set of those. Craig, I recently had to replace my electric air compressor too, and I got this Briggs and Stratton 3-gallon pancake, at Walmart I think (it may be Chinese made). Works well so far. For as little as it gets used, I couldn't see spending more for Porter Cable, Makita, Craftsman, Milwaukee, etc.
« Reply #13 on: February 20, 2024, 05:44:21 AM » |
And now for my next wonder tool. Fuzzy tooth pics. My 94yo mom put me on to these, after I was complaining to her about using dental floss (I used wider dental tape). Brushing is easy, but floss is always a chore with fingers in your mouth. And I once lifted off an old dental crown with floss. The gap at the top of teeth may be narrow (having to force the floss through), but the gap at the gum line (where food gets lodged) is always wider. There are several makers, and they come in up to 5 sizes (of the little brushes). Brush for as long as you want, then go back with the tiny brushes and you always get the little bits of cavity causers out anyway. I keep them in both bathrooms and on the kitchen sink. Marvelous invention. Much easier and faster to use than floss. And a dentist avoidance tool.
« Last Edit: February 20, 2024, 11:15:36 AM by Jess from VA »
Farside
Let's get going!
S. GA - N. FL
« Reply #14 on: February 20, 2024, 06:06:13 AM » |
Just to change things up (and avoid current events), lets talk about tools (equipment, gear, kitchen, yard, you get the idea). My Amazon bench grinder came today (my old one died last year). DeWalt 6"; Grinding wheels course and fine, buff wheels, wire wheels). It's mostly used to clean up many of your other tools and equipment (or rusty nuts). I use the grind wheels once in a while, but otherwise keep it loaded with a stiff wire wheel on one side and a hard cotton buff on the other (with various polish compounds). They get used all the time. I have a small shed workbench, but won't give up the work space. So I bolt it to a short sturdy stool with rubber feet, and can move it anywhere I want to use it. It's better throwing sparks outdoors than in my sheds with the gasoline and flammables. Portable, I can work sitting, kneeling or standing. Before removing the grind wheels to stick on the wire and buffs, I used the fine grind wheel to sharpen up some loppers, clippers, hedgers, axe, adze, hatchet, machete, shovels, and anything else I could find that could use an edge.  So probably, given my previous history, in the near future, I will be known as 3 finger Jess. DEWALT Bench Grinder, 6 Inch, 3/4 HP, 3,600 RPM For Larger Grinding Applications (DW756) https://www.dewalt.com/product/dw756/6-150mm-bench-grinder So what stuff (tool) do you have? Well that sure does look like it will do the job and much faster than mine.
Farside
Jersey mike
« Reply #15 on: February 20, 2024, 06:24:06 AM » |
This isn’t as flashy as a nice bench grinder but;
One of my favorite go to tools is a 10” magnetic screwdriver, it holds numerous tips in the handle and is a great little tool to have. The unfortunate part is sometimes the magnetic head is a little too wide to fit in small openings. When that happens I have longer tips which will fit the head. The great thing I love about it the shaft is shaped like a pencil (pentagon/hexagon) and is easily spun between 2/3 fingers when starting or removing a screw.
« Reply #17 on: February 20, 2024, 06:36:42 AM » |
While having the right tool for the job makes life much easier, I find having an acceptable tool for the job ON HAND is even better.... I go almost no where without my Gerber Center-Drive multi-tool. Upgraded from the crappy OEM belt pouch to a very nice Kydex holster a few weeks ago that seems to be working well. It also draws the eyes away from another tool in a Kydex holster that I carry just behind it.
Never ask a geek 'Why?',just nod your head and slowly back away...  IBA# 22107 VRCC# 7976 VRCCDS# 226 1998 Valkyrie Standard 2008 Gold Wing Taxation is theft. μολὼν λαβέ
Farside
Let's get going!
S. GA - N. FL
« Reply #18 on: February 20, 2024, 06:37:46 AM » |
 This is the only time I use the wife around my work bench. She turns the wheel for me and does a fine job too, makes her feel good that she is helping out. I am due for a new grinder stone.
Farside
« Reply #19 on: February 20, 2024, 06:52:20 AM » |
It also draws the eyes away from another tool in a Kydex holster that I carry just behind it.I have a big assortment of nice Kydex and leather for various tools. And the proper belts to go with them (a great holster and Walmart belt is a poor rig). But I have long been sticking my Kahr P380 (with trigger guard laser) in my pocket (front or hip) with no holster at all. It hardly prints (beyond a cell phone look), and I never have to worry about flashing. And great in hot weather. Keys, wallet, folder blade, pistol and out the door. No having to get rigged up (lazy). I do prefer 9mm, but the 380 with top hollow points will do. On the (very) rare occasion where I may go someplace riskier than usual, I can upgrade. And there's always something better in the truck.
« Last Edit: February 20, 2024, 07:34:14 AM by Jess from VA »
signart
« Reply #20 on: February 20, 2024, 07:24:42 AM » |
My newest tool. Sometimes I work late and forget to lock the door.
« Last Edit: February 20, 2024, 07:28:18 AM by signart »
« Reply #21 on: February 20, 2024, 01:44:16 PM » |
I sometimes go to the store and look at stuff but, in general, because I built the observatory, house, garage and workshop, I don't really have a need for more tools at present. Just some of the stuff I have that still works. The "Radial Arm" saw is a Sears Craftsman device. I still use it to for ripping boards and cutting precise lengths. The vacuum is also a Sears Craftsman device. Both circa late 1990's (best guess since I used them to build observatory which was circa 1996 or so.)  I purchased a Dewalt Chop saw in the 2000's sometime (again for house construction). Not sure of the date  Wife even used it once while we were building the house.  I got a bunch of other stuff, various drills and impact wrenches and nail guns and grinders.  And of course several standard battery operated drills. Just one, the red one, is Li oh powered and it is the one where the battery lost charge after sitting for a couple of months not being used. Keep one in the charger at all times now. NiCads seem to not have the issue.  So why it might be "fun" to get some newer stuff, as long as the stuff I have still works, I will just have to be old school. What I could use (not often but...) would be a drill press but.....
« Reply #22 on: February 20, 2024, 02:53:51 PM » |
The thread wasn't just for new stuff Jim. Any tools will do (like that old hand crank grinding wheel). A lot of my stuff is older; I take care of it and don't wear most out. Some just dies of old age. Impressive collection. Is all that stuff in a garage, or is there a workshop? I believe I have the identical DeWalt compound miter saw. I used it to make some 6 and 8 sided planter boxes and a few other things. But now mostly I just use my circular saws. I'm no finish carpenter. Just Harry Homeowner.
« Reply #23 on: February 20, 2024, 02:56:20 PM » |
The biggest problem about having tools (for me at least) is having the room for them. I have wanted a lathe for a long time. But I’ve got my garage filled with more “stuff” now than I can easily use. I have a 20 x 20 carport that I’ve thought of converting into a shop. My next big project will be an outdoor kitchen area adjacent to the pool. Maybe after that I will convert the carport. By the time I get everything I want it will be time to go into a home.
« Reply #24 on: February 20, 2024, 07:03:24 PM » |
It is now in a workshop. Just built it four or five years ago. Built the garage first. Workshop is the same basic design just located 100 yards further down the road.  Here is the workshop, minus the roll up door in the open space.
RP#62
« Reply #25 on: February 20, 2024, 07:27:03 PM » |
My grinder (see below) was in the shop I was working at when I was 19. I was a mechanic's helper at the time, doing maintenance for the local Navy Flying Club. I thought the grinder belonged to the club, but it actually was owned by my boss. He was one of the best bosses I've ever had and I learned a lot from him and we became good friends. Some time later, I married one of his daughters. A couple of years ago, right before he passed away he had me go through his shop and get whatever tools I wanted as he knew he wouldn't be using them anymore. That's when I saw the grinder and I knew it was that one I used as a teenager as its the only one I've ever seen with the words "no step" stenciled on it. We used to laugh about that - he said he had no idea why it was on there, that it was on there when he got it. So when I overhauled the grinder and repainted it, I restenciled "no step" on it, for old time's sake.  -RP
« Reply #26 on: February 20, 2024, 07:36:09 PM » |
Good story RP.  My first wife was a farmer's daughter. When she left, I missed him more than her.  I seem to recall the "no step" stenciled around Navy yards, boats, and fabric airplane wings near the doors.
« Reply #28 on: February 21, 2024, 04:02:42 AM » |
Built the garage first. Workshop is the same basic design just located 100 yards further down the road. Beautiful work on the garage and shop.  That much property in my county would be taxed to pieces. I've always liked those metal roofs. Seem so much better than shingles, and less prone to leaks (and expensive repair and replacement). I guess they cost more than shingles to start, but outlast them. I would kill for a garage and workshop. My truck is parked in the drive, and all my bikes, tools, and equipment are housed in 2 identical side by side 10 X 12 wood sheds. Wired for 110, double 3/4" marine grade plywood floors, and brand new shingle roofs and double doors. I'm on 1/3 acre lot. Wood floor sheds are considered movable and thus allowed (by county code) to be much closer to the property line than permanent concrete floors (like 3 feet instead of 10/15 feet). Same deal with building size (and height); I couldn't build one big building (instead of 2 10 X 12's) and put it 3 feet off the property line. Code enforcement is a big thing in my urban county, and they will fine you (daily) and make you tear things down. Years ago, I ended up seeking a (fairly minor) variance in front of the local Board of Zoning Appeals and it cost me 2 property surveys, $2500, and a lot of grief to win. In preparation for the formal hearing, I was in contact with the Board's clerks routinely, and one told me the Board was leaning toward denying my request. I told her to tell the Board I was an attorney, and if I lost, I would appeal to Circuit and Appeals courts if necessary (I was highly pissed off at this point). So, I won my case (actually televised on a local channel). And stuck to code from then on. The county is not my friend.
« Last Edit: February 21, 2024, 04:06:44 AM by Jess from VA »
Timbo1
« Reply #29 on: February 21, 2024, 08:23:54 AM » |
I often find myself buying old cast iron tools and repairing them to sell or use in the garage if I have the need. Between the yard equipment, tools and bikes I'm in desperate need of a second garage. Most my tools function very well (with some sweat equity) but were for the most part inexpensive for me to purchase. Some are just cheap tools that I didn't expect to last more than a year or two.
Dunlap 8" Bench Table Saw MD:103.22880 1940's - 1950's Craftsman 10" Table Saw w/Vega Pro 48" fence MD:113.298032 1983 Craftsman 12" Drill Press MD:113.24590 Late 1960's - Early 1970's Craftsman 6" Jointer MD:103.23320 Late 1940's Craftsman 6" x 10" Belt / Disc Sander MD:103.22500 1950's - 1960's Craftsman 12" Bandsaw MD:113.243311 1985 Central Machinery 14" Bandsaw Dewalt 735 Planer 36" x 33" Homemade CNC Router w/2HP Dust collection system Dayton 6Y945 Belt / Disc sander Jet BD-920 Metal lathe Chicago Electric 8" Bench Grinder Chicago Electric 10" Compound Miter Saw
« Reply #30 on: February 23, 2024, 06:21:12 AM » |
Years ago, I ended up seeking a (fairly minor) variance in front of the local Board of Zoning Appeals and it cost me 2 property surveys, $2500, and a lot of grief to win. In preparation for the formal hearing, I was in contact with the Board's clerks routinely, and one told me the Board was leaning toward denying my request. I told her to tell the Board I was an attorney, and if I lost, I would appeal to Circuit and Appeals courts if necessary (I was highly pissed off at this point). So, I won my case (actually televised on a local channel). And stuck to code from then on. The county is not my friend. Jess, I feel your pain. But, as a Code Enforcement Officer, one thing I've learned, everyone hates zoning bylaws and dealing with zoning boards or officials until their neighbor installs a chicken coop next to their property line. Recently, I updated my older DeWalt 18volt cordless tools, the old batteries just couldn't cut it anymore and replacing them didn't seem prudent. I updated to new 20volt DeWalts including skill saw, reciprocating saw, impactor, drill and 1/2 mechanics impactor. Then I bought this  A buddy of mine has a large blueberry field that has been ignored for a decade or so. As a hobby, I plan on bringing it back to production stage.
« Reply #31 on: February 23, 2024, 03:04:56 PM » |
But, as a Code Enforcement Officer, one thing I've learned, everyone hates zoning bylaws and dealing with zoning boards or officials until their neighbor installs a chicken coop next to their property line.I hear you Bill, (and turned in my old neighbor for a dozen violations all under the heading of keeping his place like a big junk and garbage yard, with barking dogs). They finally moved. The way it works here is they only respond to complaints. Well the complaint on me was the terrible neighbor in retribution. Though my property is always pristine. My violation was ignorance, but once called, you get the full treatment for anything they may find. Walking my big neighborhood for a long time, and knowing the rules now, I see dozens of code violations every day in plain view. But if no one complains, then there's never any trouble. There is a rooster somewhere on the other end of my neighborhood and he's crowing off and on all day. Not that I hear him at my house, and I would not call on it. But it is a compete mystery where he is located. That would be irritating, next door (or even down the street). I eat blueberries ever day (breakfast).
« Last Edit: February 23, 2024, 03:07:13 PM by Jess from VA »
« Reply #32 on: February 23, 2024, 04:13:38 PM » |
The way it works here is they only respond to complaints. Jess, that's the only way I work it, I have a complaint form as a TOOL (now this is related to the op) that has to state the code or bylaw being violated or nothing happens. People like to use the office as a TOOL  to get at their neighbors. I like using my DeWalts.
« Reply #34 on: March 03, 2024, 11:30:03 AM » |
Jess - Along the lines of your floss post - My hygienist told me about a product called Shower Floss. Like a Water Pic but installs in your shower & you squirt your teeth when you shower. Bonus, you can flush the wax out of your ears and keep them clean. In fact my VA audiologist (or ear doctor) said my ears are unusually clean. Amazon has it.
« Reply #35 on: March 03, 2024, 03:54:23 PM » |
Nice bench tool Mark.  No way in heck I'd squirt water in my ears. It used to take me days to get pool and lake water OUT of my ears. Maybe a Qtip with some alcohol on it, carefully/gently. Now like most of my old skin, I'm drying out, and my ears itch if I don't cream them up a little. Itchy ears are quite bothersome, esp in a bike helmet with leather gloves on.
ptgb
« Reply #36 on: March 05, 2024, 09:21:55 PM » |
I just built this... only because I had no room for my new table saw.... ...and just maybe because I was running out of cordless tool storage... but mainly because of the table saw   Empty space = MORE TOOLS!!!
« Last Edit: March 06, 2024, 10:52:10 AM by ptgb »
 Lower Lakes 1000 - 07/07 & 09/10 * Bun Burner GOLD - 09/10 Lake Superior 1000 - 07/11 * Lake Michigan 1000 - 09/11 * Lake Huron 1000 - 09/11 Saddlesore 2000 - 09/11 * Ohio 1000 - 07/13
« Reply #37 on: March 05, 2024, 09:42:59 PM » |
Very nice!  When do you have time to watch the TV?
