February 11, 2026, 11:25:15 AM *
Author Topic: Gas Leak At Fuel Rail.  (Read 2147 times)
hueco
WACO,TEXAS
« on: March 09, 2024, 02:21:20 PM »
Got everything back together after replacing slow speed (pilot) jets. Running like it should again. Now. There is a gas leak at the fuel rail coming out of #2 carb. I tighten the nuts at the end of carb bracket as I read to do in another thread. Still has leak. I was hoping it would seal off. No luck thus far.  I dread taking it all down again, even further this time. Just to replace a couple of 10 cent o-rings. Has any one had to replace these? Does anyone know what size the o-rings are and where to source them? Thanks.
« Reply #1 on: March 09, 2024, 03:05:32 PM »
try also tapping the carbs together with a wooden dowel and tighten those end nuts.
hueco
WACO,TEXAS
« Reply #2 on: March 09, 2024, 04:21:59 PM »
Thanks. I'll try anything to keep from having to pull everything again.  Any and all suggestions are appreciated. cooldude
longrider
Vernon, B.C. Canada
« Reply #3 on: March 09, 2024, 05:59:05 PM »
How long has gas been in the rail.   If only a few hours start it again till gas leaks then shut off and wait overnight.    I’ve had mine swell up after sitting overnight never to leak  again until the carbs are drained and the orings shrink again during winter storage
« Reply #4 on: March 09, 2024, 07:02:42 PM »
Agreed  cooldude
« Reply #5 on: March 11, 2024, 10:21:53 AM »
I ordered and used these from McMaster-Carr.  No problems thus far.
Oil-Resistant Soft Buna-N O-Rings, 1.6 Mm Wide, 7.1 Mm Id
1174N302
Pack of 50
$21.34
Pack
$21.34
Oil-Resistant Soft Buna-N O-Rings, 2 Mm Wide, 8 Mm Id
1174N429
Pack of 50
21.34
Pack
21.34
hueco
WACO,TEXAS
« Reply #6 on: March 11, 2024, 06:51:48 PM »
Thanks, Skinhead. I used a piece of nylon rod as I didn't have a wooden dowel. And. Tapped the #3 carb in. It helped quite a bit. Still has some seepage. Hoping it will seal off. Seems like I fix one problem another pops up to replace it. Whack a mole.
« Reply #7 on: March 12, 2024, 07:21:53 AM »
On the bike I replaced the O-rings on, it had been neglected and was leaking fuel when I tried to start it.  I hoped the O-rings would swell and seal, but they didn't.  When I rebuilt/cleaned the carbs, I found deposits on the O-rings that I believe prevented them from sealing.  I don't know if they were from the fuel or possibly additives the previous owner may have used.  Either way, the O-rings above did the job.  Be sure to lube them with Vaseline when you install them.
Led
Wisconsin
« Reply #8 on: March 20, 2024, 09:24:41 AM »
YUP!!  Been doing this for years.  Mine only take a couple of hours to swell back up....so far!!!  But it works for me!!!
« Reply #9 on: March 20, 2024, 10:18:34 AM »
seafoam shrinks O-rings,  B12 Chemtool swells O-rings
https://bobistheoilguy.com/forums/threads/my-o-ring-swelling-test.129732/
wrote about seafoam before
https://www.valkyrieforum.com/bbs/index.php/topic,123521.0.html
