February 11, 2026, 11:25:10 AM *
Author Topic: excellent Metric supply site  (Read 2086 times)
« on: March 26, 2024, 05:42:34 AM »
https://belmetric.com/
nuts, bolts, hoses, clamps, fittings etc.
h13man
Indiana NW Central Flatlands
« Reply #1 on: March 26, 2024, 05:55:00 AM »
Also http://www.allensfasteners.com/default.asp They also carry electrical terminals etc. Just restocked last week. Damn shipping was $11 but the price is still cheaper than the gas to do 50 mi. round trip to town and MAYBE find everything you need.
mello dude
Dayton Ohio
« Reply #2 on: March 26, 2024, 07:09:00 AM »
2nd that, I have used belmetric several times for fasteners....quality stuff  cooldude
If you want to go a bit exotic, ProBolt is fantastic with aluminum, stainless steel and titanium fasteners.
Definately expensive, but the quality from ProBolt is off the charts, parts are like little jewels.
https://www.probolt-usa.com/
« Last Edit: March 26, 2024, 01:22:46 PM by mello dude » Logged
WintrSol
Florissant, MO
« Reply #3 on: March 26, 2024, 10:38:09 AM »
Bookmarks saved, thanks guys. Now I don't have to search as much for 'that' fastener. cooldude
« Reply #4 on: April 01, 2024, 02:21:57 PM »
Those flat head set screws that are hard to remove can be replaced. Here is the site for the right size.
https://belmetric.com/m10x1-0-extra-fine-allen-set-screw-stud-din-913-stainless/?sku=SS10X1.0X8FLATSS
h13man
« Reply #5 on: April 02, 2024, 06:16:29 AM »
A suggestion, put anti seize on all your fasteners especially those going into aluminum. No damn Loctite needed on a Valkyrie unless Honda says so but I haven't seen that yet in my OEM but...  Wink
« Reply #6 on: April 03, 2024, 07:16:52 AM »
The only Loctite I have used on the Valk is on the alternator front nut that holds the drive flange.  I had one come loose on me and I thought the valvetrain was coming apart.  I put Loctite on it, torqued it to specs, and placed it on the shelf as a known good spare.
Hay  Cool
« Reply #7 on: April 03, 2024, 09:55:28 AM »
Don’t the pins for the rear hub damper require thread locker ?
« Reply #8 on: April 05, 2024, 05:20:01 AM »
No, and no grease on the pins either, per section 14 of tech manual.
Speedy Coop
South Wales, New York
« Reply #9 on: April 05, 2024, 07:43:39 AM »
My Clymer  manual says ' Caution, Do not attempt to remove the final driven flange pins and nuts ' and to apply a light coating molybdenum disulfide to the driven flange pins.
« Reply #10 on: April 05, 2024, 07:52:50 AM »
clymer has had many mistakes over the yrs for many different vehicles.
Factory tech manual should be followed in this case, since its best to have the least amount of movement as possible in the dampers and splines.
Speedy Coop
« Reply #11 on: April 05, 2024, 10:26:50 AM »
I have an OEM manual for my 2008 Kawasaki Concours C14 that has a mistake in it for valve clearance computation if I am remembering properly. I believe it was corrected for later models. Sometimes you have to do what you think is right.
h13man
« Reply #12 on: April 11, 2024, 05:46:27 AM »
The 06' VT1100C Clymer manual had at least one miscue and that was the procedure doing rear end refill of the lube thus causing overfill and a mess with rear tire receiving most of it. I've always purchase OEM most the time but I'd say Clymers is 2nd. best in a pinch but w/o a good forum and/or a OEM, how you know what truly right?
GO OEM!  Grin
