February 11, 2026, 11:24:42 AM *
Author Topic: Starter Switch difference between interstate CF and touring C/CT  (Read 1699 times)
Racernick
« on: April 03, 2024, 07:09:31 PM »
Hey all so starter switch went out on the CF so having a parts C/CT at the house took the switch off it.  It worked to start the bike but had one wire different the CF. Not sure what the difference in the wire switch would be any ideas???  Just noticed now with that switch installed the headlight doesn't work. Not being near the bike currently i can’t unplug it and see if  headlight turn back on after unplugged will be my first test when i see the bike again.
Cf part numbers are 35013-MBY-010 or 35013-MBY-000
C/CT part number are 35013-MZO-010 or 35013-MZO-010
« Reply #1 on: April 03, 2024, 08:09:52 PM »
The Interstate models have a relay wired in to their starter circuits. I suspect this is the difference. I imagine there is a way to get around this, but I’d have to check out the wiring diagrams. Most of the time the starter switch assembly can be cleaned up to work just fine.
Jims99
Ormond Beach Fl.
« Reply #2 on: April 04, 2024, 04:47:53 AM »
Interstate housing and wires are different. Throttle cables come out in a different way. Headlight runs through the starter switch and will not work if not wired right. 90% of the time the switches can be cleaned up and work just fine. First try soaking all of them (left and right side) with WD-40 and moving them on and off. If you have to take them apart to clean, do it in a plastic bag incase a spring goes flying. The old grease in them thickens up and WD usually works just fine.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #3 on: April 04, 2024, 04:59:59 AM »
Keep the Interstate assembly. Crack both open and just replace the little white plastic switch unit. Or, just do the maintenance to get the IS one working again.
« Last Edit: April 04, 2024, 05:01:33 AM by Chrisj CMA » Logged
Joe333x
Boston
« Reply #4 on: April 04, 2024, 09:31:53 PM »
This stuff works well for switches. My high beam switch was intermittent and now works perfectly.
https://www.autozone.com/miscellaneous-cleaners-and-degreasers/electrical-parts-cleaner/p/crc-qd-electronic-cleaner-11oz/128435_0_0?searchText=Qd+cleaner
Jims99
Ormond Beach Fl.
« Reply #5 on: April 05, 2024, 04:59:13 AM »
[/quote]
I use that also, but only when I pull them apart to clean. This takes the grease away then I add new grease.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Steel cowboy
Spring Hill, Fl.
« Reply #6 on: April 05, 2024, 07:23:27 AM »
I believe there is a difference since Interstate models have acc all the way to the left on the ignition switch for the radio to stay on when engine is off and lights too
2001 black interstate
2003 Jupiter Orange wing
Joe333x
Boston
« Reply #7 on: April 06, 2024, 01:28:28 AM »
What parts are you adding grease too? I thought we were talking electric contacts here.
Jims99
Ormond Beach Fl.
« Reply #8 on: April 06, 2024, 04:49:34 AM »
Dielectric grease. Helps keep out water and corrosion. Does not conduct electricity so nothing will short out. Use it around the contacts. If it gets on them, it will move off when switching on and off. I also use it on lightbulbs, mainly on my trailers.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
