November 05, 2025, 04:43:50 PM *
Author Topic: Today's Task - (Not Directly Valkyrie Related)  (Read 845 times)
« on: April 11, 2024, 02:09:59 PM »
Todays Task.
Rain water is a very powerful force.  Especially when it gets a chance to run down hill.  It can easily wash away gavel and even rocks and dig deep trenches in gravel layered roadways.  So.... today's task:  To undo what the rain had done over the past year or so.  Just some after pictures.  I should have taken before pictures, but..... I was into the task for a change.
The results.
And this is the tool used.
It is amazing what one can do with the right tools.
« Last Edit: April 11, 2024, 02:47:00 PM by carolinarider09 » Logged
« Reply #1 on: April 11, 2024, 03:50:02 PM »
I have no tractor, but I have several shovels, a pick, a hoe, an axe, and a digging bar (and a sore back Grin).
The lower half of my small suburban backyard has become one big drainage ditch.  Rainwater used to pool up deep enough to float a canoe, and take a long time (days) to percolate in solid (lousy) clay soil.  In the past, I put a submersible pump back there and ran a hose over the fence to the street (to the storm drain) and it would run for hours.
Last year, I dug a drainage ditch inside my solid back fence and a drain hole (with 6" tube) from the ditch under the fence (in completely root bound soil I had to use the axe to chop up).  So now I don't get a lake down there anymore.  Just a big mud hole.
The mud hole got improved a bit recently when a neighbor got a new driveway, and I trucked home a big pile of jack-hammered concrete chunks I threw down in the bottom of my drainage ditch.  It's still a mud hole, but now I have something to step on.
It was either this or I was going to stock it with some small fish and a couple turtles.
Regular rain is not a big problem, but we get enough torrential downpours and monsoons reminiscent of Noah and his big boat which is a problem.
I'm happy it's not really visible to the public, only me.  And I try not to look at it.
« Last Edit: April 11, 2024, 03:52:58 PM by Jess from VA » Logged
LadyDraco
TISE
« Reply #2 on: April 11, 2024, 04:17:01 PM »
A  tractor  saves  the  back ! cooldude
This  is  the  way
« Reply #3 on: April 11, 2024, 05:00:43 PM »
 cooldude cooldude
« Reply #4 on: April 11, 2024, 05:37:37 PM »
A friend bought some property in Alabama and built a big shed on the property. Well during the rain the flow came right at the new building and he does have a tractor and made some diversions for the water. He was seriously worried about the building being washed away. He had lived in Africa you would think he would know this.
