November 05, 2025, 01:28:44 PM *
Author Topic: Adjusting the I/S clock!  (Read 961 times)
« on: May 26, 2024, 11:41:18 AM »
Not sure if this is correct board but...I can't figure out how to set the clock on my I/S trike. I don't have an owner's manual and didn't find the instructions in the Honda shop manual. So, can someone shed some light on the procedure? The clock works, just wrong time showing. TIA
« Reply #1 on: May 26, 2024, 11:52:18 AM »
    I have fergitted the Exact sequence John But the clock adjusts of the radio controls. I seem to recall someone covered this on the 1500 tech board. Also seem to recall Jess has some insight on this. RIDE SAFE.
LadyDraco
TISE
« Reply #2 on: May 26, 2024, 12:14:48 PM »
Turn the  key on. The  bike  doesn't  have  to be  running .
Make  sure  you can see  the  wrong time...
when you tap this  button You might have  to hold  it down till you hear a  beep
the clock will start flashing
then  up on Volume   is  hours down is  min..
Once  you are  happy  with the time , tap that clock button, that  hold  your  time setting...
« Last Edit: May 26, 2024, 12:18:52 PM by LadyDraco » Logged
This  is  the  way
« Reply #3 on: May 26, 2024, 12:19:05 PM »
 cooldude cooldude
« Reply #4 on: May 26, 2024, 01:58:29 PM »
With only very rare exceptions, I haven't cared what time it is for 14 years (of retirement).  I may have actually set my bedroom alarm once in those years.  My 2 interstate's clocks have never been set.
It is light or dark out, or raining or snowing?  Those I care about.
I have 6-7 watches, two of which are very nice and a bit spendy.  They all sit in the safe.  And if I do need one, I wear the little cheap Timex on nylon strap.
Of course there are wall clocks (and all the electronic ones on appliances), and my Verizon FIOS box clock lets me know when my show or movie is coming on the TV.
« Reply #5 on: May 26, 2024, 07:55:57 PM »
Hey Tracy...worked perfect. Thanks!  cooldude
Going to send you a PM about fork covers you used to make.  Wink
