February 11, 2026, 01:20:45 PM *
Author Topic: Clutch lever issues.  (Read 2312 times)
Moonshot_1
« on: May 27, 2024, 06:06:52 PM »
Pulling the clutch lever is getting a little odd.
Have to pull all the way in to disengage and it engages very quickly.
A full pull to disengage and simply relaxing the hand at near the full pull will engage.
I am assuming from a previous thread that a bushing is a possible problem?
The clutch itself does seem to engage and disengage just fine.
Looking for some insight.
Mike Luken
Cherokee, Ia.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: May 27, 2024, 07:17:07 PM »
It could easily be the bushing. Do you know how to look at it, evaluate it, and replace it if needed?
Dusty
Mill Bay B.C.
« Reply #2 on: May 27, 2024, 10:29:55 PM »
Clutch lever bushing
The Honda part Number 2285-MBO-006 is $10
The Suzuki part number 59892-08A00 is $3 and exactly the same part.
Part number two in the drawing
Courtesy of NC_Rob
Here is the info for bushing
Dusty
Moonshot_1
« Reply #3 on: May 28, 2024, 11:39:31 AM »
I am confident the issue is the bushing. It appears to be easy. Appears. I've been tricked before thus my post. I tend not to be mechanically inclined.
Kind of looking for a simple "tutorial" from you guys in the know.
My concern is does this get me into the actual hydraulics and having to bleed lines and such or is it a simple remove lever and swap out bushing. (and pin?)
Mike Luken
Cherokee, Ia.
« Reply #4 on: May 28, 2024, 01:22:23 PM »
Simple. No bleeding necessary.
« Reply #5 on: May 28, 2024, 04:41:45 PM »
Bushing problem, always there.
Clutch rivet, distance of pull comes and goes.
Bushing $3 USD ($5 CAD) and us easy to replace. Problem goes away, most likely it was that. Same, then put the bushing in your spares and look further.
Moonshot_1
« Reply #6 on: May 28, 2024, 06:02:04 PM »
Always there. Pretty sure you guys called it. Thanks. Got part ordered.
Mike Luken
Cherokee, Ia.
Moonshot_1
« Reply #7 on: June 05, 2024, 02:26:51 PM »
Got parts. installed. Works like new. So simple even I could do it. Thanks for the support.
Mike Luken
Cherokee, Ia.
« Reply #8 on: June 08, 2024, 09:22:42 AM »
I got a nice chuckle with that remark, I can relate to it.  2funny
h13man
Indiana NW Central Flatlands
« Reply #9 on: June 12, 2024, 04:49:16 AM »
Welcome to the club!  Grin Grin Grin BTW if you get tired of the "pull" with this MC, 1800 VTX MC works much easier. Yeah I'm old.  Smiley
