November 11, 2025, 06:03:56 AM *
Author Topic: Shifter shaft fast leak  (Read 1550 times)
Gearhead24
Sacramento
« on: June 02, 2024, 11:12:52 AM »
Hello,
This morning I noticed a big puddle of oil under the bike. Hoped it was nothing but when I started it I saw a fast leak coming from the shifter shaft (2 or 3 drops per second). Going to get that fixed asap but what would be a cause of this. I don’t feel any trouble shifting except for 1 and 2, besides that it’s smooth shifts with no play in the shaft. This week was the first time I was consistently riding every day and first there was a coolant leak(solved), then a fuel leak (solved itself), and now this. Can’t help but feel superstitious
Mooskee
Southport NC
« Reply #1 on: June 02, 2024, 11:58:31 AM »
Need to replace the seal on the shifter shaft. Pretty easy job, and the seal doesn't cost much. Might also consider a Shifter Buddy from Steve Cain. I think it makes shifting more solid and protects the seal.
« Reply #2 on: June 02, 2024, 12:29:33 PM »
While you’re waiting for the part, remove the shift lever and push the seal all the way in. When I did that there was no leak to fix for almost a year. When it started leaking again I changed the seal.
« Last Edit: June 02, 2024, 12:37:50 PM by Chrisj CMA » Logged
Gearhead24
Sacramento
« Reply #3 on: June 02, 2024, 12:42:25 PM »
Thanks for the advice. I’m gonna get the part ordered now and try that temp fix. I’ve heard a lot about that shift buddy and now that I have a few extra bucks I might get that. Got a lot of stuff I’ve actually needed for this bike but haven’t been able to get yet cause of money. At least im not out of a bike yet. I’ll be able to use my brothers shadow 750 while I’m waiting for this part
Gearhead24
Sacramento
« Reply #4 on: June 02, 2024, 12:45:33 PM »
While looking at the shift drum + shift fork diagram on oem website I see part no 91206-286-013 is a small circular oil seal. Looks to be the right part, just wanted to double check
-mike-
Germany
« Reply #5 on: June 02, 2024, 12:49:18 PM »
That's the right one.
Happy wrenching!
-mike-
« Reply #6 on: June 02, 2024, 12:55:38 PM »
It takes 20 min to r/r the shift lever and reseat the seal.
Gearhead24
Sacramento
« Reply #7 on: June 02, 2024, 12:56:15 PM »
Happy wrenching!
-mike-
[/quote]
Thanks, just got two ordered just in case. If I’m gonna be superstitious might as well cover my butt
