November 20, 2025, 09:52:23 PM *
Author Topic: I really screwed up!!!  (Read 3880 times)
SgtBunny
"Don't be a Lemming!" - MCC
Kingwood, WV
« on: February 13, 2010, 10:46:16 AM »
I went out to start my bike this morning and realized I screwed up.
I hit the key and it turned over a couple of times and tried to fire.
The next thing I hear is the starter clicking and the motor not turning.  Sounds like a low battery sound, which it was low so I had it on a battery charger set on boost to start.
It does not sound like a chunk of metal bouncing around inside.....yet.
Looks like I may have hydrolocked it.
What's the chances of damage?
I started taking chrome off to get to the plugs and realized my plug socket will not fit so
I am going to have to go buy a new one.
any thoughts?
thanks
« Last Edit: February 13, 2010, 10:52:56 AM by SgtBunny » Logged
VRCC #29625
'98 Tourer
« Reply #1 on: February 13, 2010, 11:13:03 AM »
my thoughts.  I re-read your post.  If it truely turned over a few times then its NOT hydrolocked.  If it were hydrolocked it would have made a partial rotation to a hard stop and thats all she wrote.  You are on the right trck to remove the spark plugs, but I suspect you will find no gas, and need to jump her to get her started.......my diagnosis (no guarantee) is a bad battery
Anthony
Belgium
« Reply #2 on: February 13, 2010, 11:15:12 AM »
calm down,
if the engine turned over a couple of times, you don't have a hydrolock :
if you would, then the liquid in the cylinder can not be compressed, and it would not make 1 turn.
check your battery voltage, alarm,  fuses, ...
if you are not certain / afraid to break something more : try to push start it :
 sit on it , make a little speed, drop it in 2nd gear.
if it stops like a brick, its locked,  Undecided
if it takes of like a rocket, hold on  Wink
Anthony
« Reply #3 on: February 13, 2010, 11:40:33 AM »
  You could also just remove the timing cover center section and put a socket on the crankshaft nut and see if it will turn over.. Kinda sounds like you have valances and will take a week or so to get at the sparklers..
  I'm also with the boys, if the engine made a revolution or two I  doubt you're fuel-locked.. The battery has to be in pretty good shape to start one of these monsters..
« Reply #4 on: February 13, 2010, 01:17:59 PM »
Agree with the rest of the gents. Battery. Your bike tool kit has a plug socket/wrench.
SgtBunny
Kingwood, WV
« Reply #5 on: February 13, 2010, 01:33:48 PM »
Sorry fudgie, original owner did not send the tool kit but I did buy a socket a few minutes ago and get the plugs out.
middle plugs on both sides were wet.
Battery is dead as a doornail again, will not even burp the horns and lights are very dim.
So, I have;
removed the bowl screws...should have done that and just let her set.
drained the tank.
pulled the plugs
I have a date with my wife tonight so it will have to set until tomorrow.
Tomorrow I plan on buying a new battery and hooking her up.  Then turning the engine over with the plugs out.
After that I will re-assemble and leave the bowel screws out if everything seems alright.
VRCC #29625
'98 Tourer
« Reply #6 on: February 13, 2010, 02:40:33 PM »
So, I have;
drained the tank.
pulled the plugs
You say middle plugs on both sides are wet......after removing the plugs, did you rotate the engine, did gas come out the sparkplug holes?  Its not usual (as far as I have heard) for multiple cylinders to hydrolock, so the story is not sounding any more like a hydrolock to me yet.  BTW make sure if its a battery you have to put the acid in that you put it on an 8hr trickle charge before installing to the bike
SgtBunny
Kingwood, WV
« Reply #7 on: February 13, 2010, 07:50:36 PM »
Just got back from date night with my wife.
I will not be touching it any more tonight but my paranoid self will be working on it tomorrow.
I plan on doing something to alleviate some of my fears after this though.  I remember reading where someone had installed an electronic shutoff that is triggered with the accessories, I think I will start with that.
VRCC #29625
'98 Tourer
Kingbee
VRCC# 576
Northern Illinois
« Reply #8 on: February 14, 2010, 08:20:15 AM »
Here's my install of the electric fuel valve
You can get it here
http://www.dan-marc.com/79-afc11112.html
1999 Interstate
2000 Interstate
2004 Rune
bigvalkriefan
On the green monster
South Florida
« Reply #9 on: February 14, 2010, 10:58:18 AM »
I have the same shut off valve. No more worries about hydrolock.
.....say to those with fearful hearts, "Be strong, do not fear; your God will come, he will come with vengeance; with divine retribution he will come to save you."
Isaiah 35:4
I know who wins in the end.
SgtBunny
Kingwood, WV
« Reply #10 on: February 16, 2010, 04:48:47 PM »
Ok, progress report.
Plugs are out, battery charged and the started turns over with no noise.
Thank God!
I have an electric shutoff ordered and will be installing it as soon as it arrives.  I am going to also take this time to gap my plugs.
Looking at the plugs it is running rich so I am hoping I can get the time to install my 38's and set everything right as well.
VRCC #29625
'98 Tourer
PAVALKER
Pittsburgh, Pa
« Reply #11 on: February 16, 2010, 05:45:44 PM »
You can get it here
Can this just be added to the existing fuel valve (so I don't have a hole in my nice chrome side cover) or does it replace it?   I would think it could be added in line somehow.... am I right?
John
Warlock
Magnolia, Ms
« Reply #12 on: February 16, 2010, 06:08:45 PM »
You can get it here
You can modify your stock petcock and still use your manual shut off. Someone was selling a plate here to do this set up.
David
tlanz
« Reply #13 on: February 16, 2010, 06:11:17 PM »
I have a new electric shutoff valve on my workbench waiting to be installed. One thing you might consider tho... Rather than powering it off the accessory output, consider tapping power off one of the ignition coils (blk/wht wire). That circuit ties into the bank angle sensor and engine cutoff. It's just a safer option, IMHO. No sense allowing fuel to flow if the engine isn't (supposed to be) running, eh?
SgtBunny
Kingwood, WV
« Reply #14 on: February 16, 2010, 06:40:57 PM »
The plates are gone....I bought the last one.
VRCC #29625
'98 Tourer
Warlock
Magnolia, Ms
« Reply #15 on: February 16, 2010, 07:04:47 PM »
Maybe he will make some more! If not you can use the write up for the petcock mod from R&M belly tank website.
David
Friagabi
Tacoma, Wa
« Reply #16 on: February 17, 2010, 12:33:44 AM »
Better check the battery! Take it to a Autozone or the like after you have bench charged it and have them check it for cranking capacity.
trantony
Keep the shinny side up and rubber side down!
Baton Rouge, La.
« Reply #17 on: February 21, 2010, 05:51:47 PM »
SgtBunny,
Just read your post and feel the need to share my experience with you. If you ever introduce any more than 2 amps to the electrical system, it's a good chance that you fried a diode in the alternator. When this happens, electrons get confused about which way to go and wires start melting. When you switched your battery charger to boost, it probably shot about 30-40 amps thru the system. Don't ask how I know  Cry. Just take my word for it. Good luck, hope this is not your case.
Leon #1860
Leon
VRCC #1860
1997 Valkyrie Tourer
2005 ST1300
2016 Polaris Slingshot SL LE
