May 07, 2026, 05:23:36 AM *
Author Topic: Relay box  (Read 8746 times)
M3TAL Chip
« on: July 29, 2024, 07:39:27 AM »
I recently went to the darkside Michelin Commander 2 205-50-17 on rear. Once the tire was back on the bike and I went for the first ride I thought I could hear some rubbing. Got home and looked under the bike and seems that I may have rubbed the relay box that is behind the battery box. I tried wedging it over a bit with a pry-bar and have not had any sounds from it since. I also put some coloring on the part (rib) that showed some rub mark and it since has not been rubbed off. Not sure if I should take the bike apart or remove rear tire to make sure I didn’t rub a hole thru that box or not. Just wondering if anyone else has had this happen and how they checked or corrected it. Thanks in advance. I’ll try to attach a picture. Can’t seem to figure out how, need help.
« Last Edit: July 29, 2024, 08:01:58 AM by M3TAL Chip » Logged
