January 30, 2026, 09:22:30 AM *
Author Topic: Brake pads  (Read 2198 times)
JimEd
« on: February 14, 2010, 09:39:35 AM »
Any recommendations for brake pads.
I am considering EBC sintered,,,would like to hear pros and cons..
valker06
Plainview,ny
« Reply #1 on: February 14, 2010, 10:09:15 AM »
did alot of research on pads, and stock honda pads seem to be the best,,  cooldude
« Reply #2 on: February 14, 2010, 11:38:06 AM »
I been happy with pads by Braking. Cheaper and they seem 'thicker' then oem.
Grandpot
Fort Mill, South Carolina
« Reply #3 on: February 14, 2010, 01:29:31 PM »
Use OEM pads.
Ratdog
Somewhere out West, Which way did I go?
« Reply #4 on: February 14, 2010, 02:35:22 PM »
If I recall correctly... EBC rotors require EBC pads.  If I remember correctly... EBC rotors and OEM pads are not a good mix.  I had premature pad wear when I tried EBC pads with my OEM rotors.  OEM pads have also been much quieter on my bike.
Make yourselves sheep, and the wolves will eat you. - Benjamin Franklin. If it ain't Zesty, it's only a two-tone.
« Reply #5 on: February 14, 2010, 03:49:54 PM »
see my two posts.
http://www.valkyrieforum.com/bbs/index.php/topic,9303.0.html
« Reply #6 on: February 14, 2010, 04:42:22 PM »
I run the sintered EBC pads and their rotors and I really like them. I wouldn't go back to the stock Honda stuff because I have better braking and no fade. Pad life is increased and rotor wear is down. The secret is to use the pads and rotors from the same manufacture. Also if you dont start with the sintered pads then dont use them stay with what you started with. This comes right from EBC.
Thunderbolt
Worthington Springs FL.
« Reply #7 on: February 14, 2010, 05:11:36 PM »
good to see your 2 cents worth on the tech board again. Smiley  OEM pads here and I think the consensus is don't mix pad and rotor types.  OEM pads with OEM rotors and aftermarket with aftermarket.
Ratdog
« Reply #8 on: February 14, 2010, 06:52:02 PM »
Thanks Thunderbolt... needed a break from it for a spell... it just quit bein' fun for a while.
