December 28, 2025, 03:38:34 AM
90 degree rear valve stem
Topic: 90 degree rear valve stem (Read 1888 times)
Peteg
August 29, 2024, 07:41:15 AM »
Do you guys have a preferred rear valve stem? or will any old 90 degree stem off amazon do?
Re: 90 degree rear valve stem
August 29, 2024, 07:51:55 AM »
Myers 90° is the best and what I have, $2.49. amazon wants $13
https://www.rockymountainatvmc.com/tires-and-wheels/myers-90%C2%B0-tubeless-chrome-valve-stem-p
https://www.amazon.com/Myers-Tubeless-Chrome-Valve-Stem/dp/B003O6SJEQ
August 29, 2024, 08:01:47 AM »
Mostly any 90 degree metal stem will do, but you want one with a good rubber (air sealing) gasket.
You have to install them all from inside, but it can be done on a flat tire with big C clamps without tire removal from wheel.
There's a bunch of old threads on here (with pics) on this subject over the years.
I have these in silver. They lay flat on the wheel and have no flex at all putting an air chuck on them. Never leaked either.
https://www.amazon.com/Augeny-Motorcycle-Tire-Valve-Stems/dp/B0CGDH82TH/ref=sr_1_16?dib=eyJ2IjoiMSJ9.-A9DTgsHlgPYxxGp3763dZYgFUWTfK75TlNTFgutJSMnVSj92UI7R2_IBVZpHvBduW6gNgyGAgq815WME4arRl9Nmp_91u7rmbrPfGra127zvPQ2d8_dMFNRtsdQ8Tus3gKjmfcSwnrUZVveNGQ1UW6GjTItN5LY5NqeMhzt0iJQFlj1UmmhYH_B40yEeXjZv8akYGKeBMnrzpj6KTS-ssXUAa5jWU8ZHABcIx-56Fk.rpWGcGQQdqxISiiH4abVr7xuIwHubeZ-Dmvjfx31ZgU&dib_tag=se&hvadid=616862913768&hvdev=c&hvlocphy=9008188&hvnetw=g&hvqmt=b&hvrand=15122629174774683841&hvtargid=kwd-488501533&hydadcr=24633_13611805&keywords=motorcycle+valve+stem&qid=1724943932&sr=8-16
Last Edit: August 29, 2024, 08:17:58 AM by Jess from VA
August 29, 2024, 12:53:15 PM »
https://patchboy.com/1-14-chrome-90-degree-bend-inner-mount-tire-valve-453-rim-hole.html
$2.05 plus shipping. With shipping still less than OEM. They last a lifetime (or at least until the rubber seal deteriorates which is longer than my lifetime).
=> InZane XXV
