September 23, 2025, 01:50:57 AM *
Author Topic: looking for ujoint  (Read 3027 times)
Jackl0426
« on: September 25, 2024, 08:19:52 AM »
Hi all
Well rocky is saying oct 15th on these parts not horrible but probably blowing smoke. I called Babbitts and they told be no release date on pinion cup or ujoint they have the shaft
 Am I screwed where am I gonna find these parts new. I found nothing on eBay what a bummer lol
« Last Edit: September 28, 2024, 12:20:12 PM by Jackl0426 » Logged
« Reply #1 on: September 25, 2024, 03:48:33 PM »
      Some Members here have stashes of certain hard to come by spares. I can NOT and I will NOT name them. Put a wanted ad in our classifieds and see if you can raise a response. RIDE SAFE.
« Reply #2 on: September 25, 2024, 03:53:48 PM »
there are new pinion cups listed on ebay and amazon.
  GW GL1500, valkyrie and GL1800 all use the same pinion cup
« Reply #3 on: September 25, 2024, 07:47:42 PM »
I probably don’t have to tell you but if you need the u-joint and the pinion cup, you also needs drive shaft. And don’t forget the oil seal that goes on the pinion cup end of the drive shaft
Jackl0426
« Reply #4 on: September 25, 2024, 08:50:30 PM »
yeah know i need all 3 the shaft is somewhat available and cup and joint are not. im pretty sure ujoint is ok but i want a new one anyways as its all apart. rocky mtn is saying the 17th of october to me on the 22nd for all 3 called again today who knows. but this just sucks i want to ride it. had no idea parts availibility is terrible. so who knows when ill get her going. yeah i got the oil seal already it was in stock lol lol thanks
Joe333x
Boston
« Reply #5 on: September 25, 2024, 08:57:37 PM »
https://www.partzilla.com/product/honda/40200-MZ0-A00?
Jackl0426
« Reply #6 on: September 25, 2024, 09:20:43 PM »
thanks problem with most places ive checked list them as in stock or orderable then u add to cart and purchase then it pops up with not available or backordered. ill call them tomorrow tho. i have heard some not great things about partzilla have u used them?
« Reply #7 on: September 26, 2024, 04:57:07 AM »
Now that you found the VRCC. Look up near the top. Click on ShopTalk I made a slide show called rear end service by Chrisj. If you never put the rear end parts back together that slide show will save you from doing it wrong
« Reply #8 on: September 26, 2024, 05:17:47 AM »
Pro Caliber shows all your parts available. Also there’s a guy selling a brand new shaft on the classifieds.
jnicks01
Clinton, IN
« Reply #9 on: September 26, 2024, 06:30:58 AM »
I've used Partszilla multiple times with no issues.  Only once they ended up not finding a part, but emailed me and refunded me ASAP.
I want to scoop out your brains and eat your knowledge.
Joe333x
Boston
« Reply #10 on: September 26, 2024, 08:28:31 AM »
Yes they are a reliable parts site and I just ordered a ujoint from them recently, and unfortunately was more expensive that it is listed for now.
Jackl0426
« Reply #11 on: September 26, 2024, 05:22:56 PM »
update. found pinion cup and driveshaft be here mid week. now just looking for ujoint would like to replace just because seems ok but wont know till i get other parts and get back together. seems ujoints are non existent with all suppliers ive called saying not available no status on availability. fingers crossed. thank u for everyones help so fr board is awsome
Joe333x
Boston
« Reply #12 on: September 26, 2024, 09:11:31 PM »
I just gave you a link to partzilla who has it in stock, I just ordered one, came the same week.
Jackl0426
« Reply #13 on: September 27, 2024, 11:21:52 AM »
Yes and thank you . I found and ordered pinion cup and shaft will be here next week. I still would like to find a u joint in case mine seems fine by inspection but would rather change it and have a spare ujoints are in stock nowhere and all I get when calling places is availability unknown I'm calling partzilla now to see availability
Just got off.the phone with partzilla. They have no ujoints in stock back ordered through Honda no dates on availability. Thank u all for your help so far
Same answer from rocky
Same from chaparral
Same from pro caliber
Same from local Honda dealers here in Phoenix.
Nothing on ebay.
No answer from anyone in classifieds here
I'll get one eventually.
« Last Edit: September 27, 2024, 12:37:39 PM by Jackl0426 » Logged
Pluggy
Vass, NC
« Reply #14 on: September 27, 2024, 12:57:56 PM »
Dealers won't have much to fit Valkyrie on-site.  Most parts are ordered from a warehouse sent to the dealer or you.  New parts come to my house from Georgia, regardless of whom I order from.  So "out of stock" means there is none in any warehouse and no dealer can get it.
Sometimes a parts website is not updated and the availability (or unavailability) is not accurate.
Jackl0426
« Reply #15 on: September 27, 2024, 02:43:22 PM »
Yes ita a bummer ujoints for valkyries are no date for availability through honda so could be months and months I can only hope ujoint is good it feels good but I won't know till I put it back together with new shaft new cup new wheel dampers and bushings. See what the ujoint then does under load during decel etc. Too bad ujoints are not readily available I'll keep my eye on ebay.
« Last Edit: September 27, 2024, 02:45:29 PM by Jackl0426 » Logged
« Reply #16 on: September 27, 2024, 04:37:36 PM »
The best way I have found to test for a bad u-joint is to clamp one end in a vise. Grap the other end with a vise grip and work it at every angle you can looking for a little play. If you can’t find any play then I’d say it’s good enough
« Last Edit: September 29, 2024, 05:09:20 AM by Chrisj CMA » Logged
Jackl0426
« Reply #17 on: September 27, 2024, 07:04:01 PM »
ill give that a test thanks for the tip
Joe333x
Boston
« Reply #18 on: September 27, 2024, 09:27:13 PM »
Same from chaparral
Nothing on ebay.
Personally I'd just order one from partzilla, if they allow it to be added to the cart and you can check out you will get one or your money back. I didn't call them, they were just the only site that allowed it to be ordered, so I placed the order and it came, you seem very determined about calling places though. My normal site I order from is Revzilla and they show out of stock and do not allow you to order, partzilla would do the same thing if they didnt think they could provide the part. The website still shows it will ship 2-3 days, what do you have to lose? $174 is a great price too, I just paid over $200.
Jackl0426
« Reply #19 on: September 28, 2024, 11:21:52 AM »
yeah i called partszilla backordered from honda none in stock no date on availability damn  ill probably back order one from rocky mountain they dont charge until part actually ships. im seeing no other option. if i find one sooner somewhere else i can always cancel. yeah only determined about calling first is because ive called probably ten places same answer backorder is available through honda but there is no date on availability so could be a long time.
« Last Edit: September 28, 2024, 09:48:25 PM by Jackl0426 » Logged
da prez
Wilmot Wi
« Reply #20 on: September 29, 2024, 06:17:21 AM »
  Jack , I have one in stock from a trike conversion. Low milage. I would not offer if it was bad.
                                                da prez
