September 23, 2025, 01:51:57 AM *
Author Topic: pinion cup shaft questions.  (Read 2335 times)
Jackl0426
« on: September 30, 2024, 06:54:11 PM »
ok folks . so i got the pinion cup and shaft. when i put the new cup and shaft together on the bench they dont feel much different than the old ones. a little less slop and play. when i pulled my old ones out the seal in pinion cup not even touching sides of pinion cup anymore severe wear so i know there is exsessive movement. could this all be improper lubeing maintainance or still ujoint issue i want to change ujoint too but no luck finding new. if i feel the ujoint it feels fine. guess ill get a vise before the weekend and test it that way. i know the dampers and bushings are way bad in the rear wheel and they will be here tomorrow could that be the hole vibration felt in footpegs between 53 and 65 and shock bushings definatly gone i have them too. any input much appreciated. Maybe only way is to just put all back together with all parts i have except ujont and see if vibration is gone. thanks all
« Last Edit: September 30, 2024, 07:11:30 PM by Jackl0426 » Logged
rug_burn
Brea, CA
« Reply #1 on: October 05, 2024, 11:12:46 AM »
Here's how it is on that topic:
The pinion cup and shaft splines are, of course, highly stressed and need full time lubrication.
You can opt for either of the two debated options:
  1. Pack the cup with grease and moly lube, and keep that shaft seal replaced and fresh every few years.
  2. Employ gear oil lubrication: Make sure those holes you will see going between the rear drive and pinion cup are kept open, and not clogged with heavy grease.   If you look close you'll see that those holes are configured to produce some pumping action to keep the pinion cup lubricated at all times.   Grease is only needed at initial assembly, and not much is needed.
Both ways will keep the pinion splines in good shape.  You gotta keep that seal fresh, and pressed down to where it seals, and if using grease, you gotta keep that fresh, too.   Using the gear oil method you just have to keep the seal fresh, and in good shape.
     I use the gear oil lube, and when I pull the shaft out of the cup at every tire change, its bathed in gear oil, no wear is seen.
     Some will claim that the holes don't connect the pinion cup to the gear oil lube in the rear drive, based on a drawing view in the manual.  But I can tell you as someone who's used CAD programs that this is only due to the draftsman failing to rotate the gear so the holes lined up before taking the cross section view.  It was done with a solid model, like Solidworks, which method has given rise to huge improvements in the quality of many, many items, motorcycles among them.
   Also, you need to grease the splines on the other end of the shaft and at the other side of the u-joint, too.
    I was surprised when replacing the shaft on mine (yes, I learned the hard way) that the new shaft, pinion cup and seal together were cheaper than a new motorcycle chain, as used on my other bike, which need to be replaced about every 20,000 miles or so!  They're more expensive, but a lot easier to replace, a trade-off, like everything in this world.
...insert hip saying here..
Jackl0426
« Reply #2 on: October 05, 2024, 07:00:13 PM »
Got all together road test 95 percent of vibration gone still some there right at 55. Now have weird clack sound under left valve cover when hot.clacks one time at start then all quiet, runs really good. Let sit for 10 no more one clack thing ride 20 min full operating temp and clacks one time really weird ghosts in this thing
« Last Edit: October 05, 2024, 08:53:57 PM by Jackl0426 » Logged
« Reply #3 on: October 07, 2024, 07:00:02 AM »
I found the 2 holes flowed oil from the differential when I had it out on the bench, stood the drive on the pinion cup and oil ran all over my bench!
Just my $.01875.
Hay  Cool
