December 28, 2025, 03:38:53 AM *
Author Topic: Timing Belt Change Link or Location?  (Read 2442 times)
Weezyrider
« on: October 09, 2024, 11:09:42 PM »
Can someone please point me in the right direction for the step by step info?   I've wasted a lot of time searching and no one ever posts a link, and i sure can't find it in the shoptalk section!  Closest i got was a brief description of how to inspect the belts, then "follow shop manual instructions to change belts".  Thanks in advance!
h13man
Indiana NW Central Flatlands
« Reply #1 on: October 10, 2024, 04:46:36 AM »
Heres a write up: http://www.valkyrieriders.com/shoptalk/carlbelts.htm
This info came from here: http://www.valkyrieriders.com/shoptalk/
Lots of useful info.
Weezyrider
« Reply #2 on: October 10, 2024, 09:04:47 AM »
I appreciate the response,  but those are the exact places I've already been.  I'm looking for step by step instructions.
Timbo1
Tulsa, Ok.
« Reply #3 on: October 10, 2024, 12:12:57 PM »
Look in the service manual pg. 8-5 and 27
Weezyrider
« Reply #4 on: October 10, 2024, 02:52:38 PM »
I only have a clymer.
-mike-
Germany
« Reply #5 on: October 10, 2024, 07:10:57 PM »
This may help:
https://drive.google.com/file/d/1UZqbQu-7esxaVJi0Hx05VTvbB_4mJqMZ/view?usp=drivesdk
I don't know when and where I downloaded it.
The shop manual you can have, too:
https://drive.google.com/file/d/1dUc0HNGdqAg-J96vA8GFIF603R7wmK4F/view?usp=drivesdk
Best of luck,
-mike-
« Reply #6 on: October 11, 2024, 05:54:09 AM »
Great write up!  Mike is this your work?
I did this so many times while chasing an oil leak, that I can do it in my sleep.
Hay Cool
F6Dave
« Reply #7 on: October 11, 2024, 08:10:49 AM »
If you search on GL1500 timing belts there are plenty of videos on changing timing belts on a 1500 Goldwing. I assume they're the same as the Valk except the Wing has a lot of plastic to remove.
Jackl0426
« Reply #8 on: October 11, 2024, 12:03:31 PM »
I found a good  vid on u tube it’s a Valkyrie
https://youtu.be/UJm8gcDQz2Q?si=hajLWoinoe9V--2t
« Reply #9 on: October 11, 2024, 12:21:19 PM »
Thanks Jack.  That guy is good.
Hay  Cool
Weezyrider
« Reply #10 on: October 11, 2024, 01:17:10 PM »
Mike, Thank You!  Excellent write up, exactly what i need!  One thing tho, the write up mentions turning the crankshaft "clockwise" to line up the marks.  When I did valve clearances the instructions said "counterclockwise" .  Should this be done rotating "clockwise"?  Looking at it from the front of bike of course.  Thanks
-mike-
Germany
« Reply #11 on: October 11, 2024, 11:17:55 PM »
This write-up wasn't made by me.
I don't know where I found and saved it years ago.
And thanks for mentioning this - You are right!
It should read counter-clockwise in fact!
I've changed that - new link here:
https://drive.google.com/file/d/1VESPBCm0uhEIR-8QjPbM1e360iqLgTWg/view?usp=sharing
-mike-
