September 23, 2025, 03:19:11 AM
Speedometer light
Topic: Speedometer light (Read 2382 times)
DIGGER
Speedometer light
October 14, 2024, 10:34:25 AM »
2001 standard speedometer light burned out 23 yrs later. How do I get to it?
Re: Speedometer light
October 14, 2024, 10:44:57 AM »
Small screw inside the trip meter roller. Remove the roller. Screw at the bottom of the speedometer case. Remove that. The light should be easily accessible.
WintrSol
Florissant, MO
October 14, 2024, 10:45:43 AM »
Yes, the screw at the back of the chrome shell uncovers the back of the 'meter'
And for 'locking agent', do not use LocTite red, or you may never get it out again; even blue may be too strong. For screws this small I go for green or purple.
Last Edit: October 14, 2024, 10:52:59 AM by WintrSol
DIGGER
October 14, 2024, 03:22:52 PM »
Got it. Thanks a lot all. It was easy. This is a great site for repairs. Will pick up the new lamp at the dealer tomorrow.
WintrSol
Florissant, MO
October 14, 2024, 04:00:46 PM »
You can also replace it with a LED of a color of your choice.
October 14, 2024, 04:51:45 PM »
Quote from: WintrSol on October 14, 2024, 04:00:46 PM
Recommended. They are inexpensive enough you can get a few and experiment with which color you like best.
Reply #6 on:
October 15, 2024, 08:21:01 PM »
I tried a few types of led bulbs. This 360 degree build gave the best results
Last Edit: October 15, 2024, 08:22:37 PM by Chrisj CMA
Pluggy
Vass, NC
Reply #7 on:
October 16, 2024, 05:39:53 AM »
Quote from: Chrisj CMA on October 15, 2024, 08:21:01 PM
Can you tell us where you got it?
Reply #8 on:
October 16, 2024, 09:44:56 AM »
Quote from: Pluggy on October 16, 2024, 05:39:53 AM
Superbrightleds.com
=> InZane XXV
