February 11, 2026, 09:28:57 AM *
Author Topic: Antenna relocation for super valk  (Read 2585 times)
anibal
« on: October 26, 2024, 04:28:09 PM »
Hello!
I've owned a standard for some time and recently bought an interstate. I've been preparing to do a super valk conversion. Luckily, there's tons of information here, so I'm already informed on transforming the trunk to a "quick release" and wiring/adding the brake light of a standard to the interstate.
One thing that I'm not too clear on is how to relocate the antenna. It looks like some people do without but I would rather keep mine for the radio and aesthetic. Here are two images I STOLE off google and the forum of some other super valks that have the antenna attached along the right-hand side bag.
If you have done something like that would you mind sharing with me how you did it?
Any other tips and tricks are appreciated.
« Reply #1 on: October 26, 2024, 04:59:23 PM »
I have a spring mounted antenna clamped to my supervalk (OE aftermarket) bag rails.
The original whip would probably be a better antenna, but the bike came this way.
Also, when the wind and speed get going, that thing starts helicoptering and has whacked the (lid) paint a couple times.  Undecided
« Last Edit: October 26, 2024, 05:14:07 PM by Jess from VA » Logged
« Reply #2 on: October 26, 2024, 06:26:45 PM »
I have seen a rubber ducky antenna used. A custom bracket is needed to attach to the bag rail.
Jims99
Ormond Beach Fl.
« Reply #3 on: October 27, 2024, 05:53:16 AM »
For FM reception, you only need about 7-10”. AM you need the longer 17-23”. So the short rubber ones work ok. I cut my stock on down to about 15” and it works great.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Bagger John - #3785
« Reply #4 on: October 29, 2024, 09:48:07 AM »
There's a powered antenna (Dakota Digital part) inside my fairing.
If I put the trunk back on I just swap the feedline plugs going into the radio.
