January 30, 2026, 09:22:33 AM *
Author Topic: Battery code question  (Read 2442 times)
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« on: February 16, 2010, 08:08:16 AM »
What is the difference between "12-BS" and "14-BS"  batteries?
roboto65
Conroe,TX
« Reply #1 on: February 16, 2010, 08:16:47 AM »
From what I see the 12BS is 180CCA Cold Cranking Amps and the 14BS is tallet by 1/2 an inch and has more CCA 200 to be exact
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
fiddle mike
Corpus Christi, TX
« Reply #2 on: February 16, 2010, 08:44:11 AM »
Thanks.
I read more than I ever wanted to about batteries, this a.m, without ever getting that info.
I'm considering trying to put a Valk battery in a '99 Magna. I can see that the Valk batter is slightly taller but didn't know if there were any other important differences.
« Reply #3 on: February 16, 2010, 08:52:34 AM »
You need to be aware that positive and negative post position could be changed.  Also the type of post configuration could be different.
fiddle mike
Corpus Christi, TX
« Reply #4 on: February 16, 2010, 09:10:47 AM »
They are the same.  Perhaps that's what  "BS" indicates.
roboto65
Conroe,TX
« Reply #5 on: February 16, 2010, 11:09:35 AM »
Is it just time for a battery on the Magna or you not getting the life on it you want the 3rd gens have had some that the Reg Rect has gone bad thus killing a battery short time had 2 in  one trip with one of our MOOT members!!
Allen Rugg
VRCC #30806
fiddle mike
Corpus Christi, TX
« Reply #6 on: February 16, 2010, 12:44:32 PM »
Not sure, yet. Battery reads 12.88V a couple hrs. after charging.
I replaced the r/r a couple of years ago after the battery boiled and burst its seams. I was up at mriders' and got a Walmart battery to get it home. JIll (my Missus and the bike's owner) is a MOOT member.
« Last Edit: February 16, 2010, 12:46:31 PM by fiddle mike » Logged
Pete
« Reply #7 on: February 16, 2010, 03:32:00 PM »
Have done this several times to V65 Sabre's and Magna's both. Always used a Goldwing 1000,1100,1200,1500 battery.
It is necessary to modify battery box to make room and rehang some components. When putting the battery in it must be tilted and slid in.
The great thing is that all the electrics line up fine, the existing battery hold strap works without change and the battery last much longer.
If you decide to go this way let me know and I can point out where the changes need to be made.
fiddle mike
Corpus Christi, TX
« Reply #8 on: February 16, 2010, 03:49:46 PM »
Thanks, Pete, but, near as I can tell, the regulator/rectifier is clogged up.  I can't measure more than 12.9 Volts @ 3000 rmp at the battery.  The battery seems to be holding 12.7V.
http://pic80.picturetrail.com/VOL839/8886703/22979274/382875147.jpg
This '99 VF750-C Magna is the  only Honda I've ever had to replace a r/r on, even once.
roboto65
Conroe,TX
« Reply #9 on: February 16, 2010, 04:08:14 PM »
Yeah well they did put it in a Dumb spot right behind the engine in all that heat  uglystupid2 we have had a few relocate it to behind the sidecover!!
Allen Rugg
VRCC #30806
fiddle mike
Corpus Christi, TX
« Reply #10 on: February 16, 2010, 05:00:25 PM »
I'm going to give that a shot. The unit is less than two years old and came with a lot more cable than the original.
