January 30, 2026, 09:22:32 AM *
Author Topic: A better way to desmog?  (Read 2414 times)
NEHI
« on: February 16, 2010, 11:43:32 AM »
   We all know how to get all that smog control stuff off our Valks, but to do with the holes. My solution: Take a 1/8-27 pipe tap and tap the small hole that is down inside the larger hole( it is the correct size to except this tap) and insert a 1/8-27 plug! After that I made up four plugs out of 308ss on a cnc lathe. Don't worry about chips getting into the engine, if you have the exhaust off they will fall right through the ports. EASY...
NEHI
« Reply #1 on: February 16, 2010, 12:00:13 PM »
http://www.flickr.com/photos/47559568@N05/
« Reply #2 on: February 16, 2010, 12:02:11 PM »
The only shortcoming I can see with that approach is when you want to synchronize the carburetors.
The barbs are to easiest way to attach the vacuum hoses needed for the adjustment.
I myself have the hoses already in place, they are a short version but enough so that I can fish them out and connect them to the gauge hoses.
When finished I can disconnect and plug them and shove the whole thing back under the air box.
« Reply #3 on: February 16, 2010, 12:05:38 PM »
Ok, I see!  You are talking about something different.
« Reply #4 on: February 16, 2010, 03:03:03 PM »
Nice to see you post its been awhile and nice job on the plugs but there's only one problem. Not all of us have access to a cnc machine I think I left mine in my other jacket. Now if you want to manufacture them for us then that sounds like the ticket and I will buy some. Grin
Momz
ABATE, AMA, & MRF rep.
« Reply #5 on: February 16, 2010, 03:41:58 PM »
I did something similar (after having the freeze plugs blow out). I tapped the inner hole and put in a button head screw, but instead of SS plugs, I used JB Weld.
A permanent fix.....!
ALWAYS QUESTION AUTHORITY!
Tropic traveler
Silver Springs, Florida
« Reply #6 on: February 16, 2010, 06:18:13 PM »
Nice looking solution NEHI. That does look like the ultimate plug off set up!
Does seem like a lot of work though. I really like the idea of using a pipe plug especially on the bottom port but unless I had the exhaust off for another reason that aint gonna happen!  Wink
9/16 cup plugs bought at NAPA have been working just fine on the top for over 30,000 miles now on my '97. I cut the bottom pipe off about 1/2" from the foot, folded it over & welded it shut then reinstalled. Only had to pull the engine guard to gain access.
Nice work. I have seen 1/8 pipe plugs in the allen wrench style in aluminum, brass & steel. You have to hunt for them but they do exist. cooldude
'13 F6B red for Kim
