1/. check you have reconnected the fuel on / off switch correctly - you can have it indicatiing "on" when actually, it is in the "off" position .
2/. How old's the battery? - even a fully charged battery might not start the engine it the battery is old - they just don't have the cranking "juice" ( amps ) required to fire the beast up - spins the engine O.K. but doesn't fire.
3/. You have no doubt checked the obvious - kill switch, fuses etc.
good luck
