September 20, 2025, 01:47:13 AM *
Author Topic: Got a new toy!  (Read 1632 times)
« on: January 19, 2025, 04:38:00 PM »
Or tool depending on your point of view.
I have some repairs and maintenance coming up soon and I think my shoulders will thank me for this purchase. My Titan has 209,000 miles on the suspension components and I think they will be first recipients of the torque this tool can provide. If all goes well, I have a set of coilover shocks for my Corvette that will replace the current traverse leaf springs. I had to get try it out so I took off one of the lug nuts on my Corvette that use a torque wrench to 100lbft. It buzzed it better than any air impact I have ever used without all the noise of a compressor or dealing with a 50’ hose.
« Reply #1 on: January 19, 2025, 05:09:36 PM »
They are OK for the smaller jobs.
Its always nice to have more tools.  cooldude
flsix
« Reply #2 on: January 19, 2025, 07:04:27 PM »
I've had that one for a little over a year and have changed a few trailer tires, mower tires and pickup tires. It's great. Wish I'd had one years ago.
2013 F6B
           ESCHEW OBFUSCATION
« Reply #3 on: January 20, 2025, 05:09:35 AM »
I wish I had bought one sooner too, they were quite a bit less when I first started considering them!
« Reply #4 on: January 20, 2025, 05:48:01 AM »
It's only a toy for the first use, then it identifies as a tool.
I got the same one and it is a body pain prevention tool, works great.
I have an 18volt one that just never could get the work done.
da prez
Wilmot Wi
« Reply #5 on: January 20, 2025, 07:10:52 AM »
  I added one to my Ridgid collection. The power is unbelievable. I bought a lower torque model on clearance. 1/2 inch drive. Rated at 125 ft. lb. torque (if memory serves me) I have used it several times and carry it in the truck.
                                                 da prez
« Last Edit: January 28, 2025, 01:19:18 PM by da prez » Logged
« Reply #6 on: January 20, 2025, 08:36:21 AM »
  I added one to me Ridgid collection. The power is unbelievable. I bought a lower torque model on clearance. 1/2 inch drive. Rated at 125 ft. lb. torque (if memory serves me) I have used it several times and carry it in the truck.
                                                 da prez
I think your memory may have failed you! Grin The one I have has a max fastening torque of 1030ft-lbs and a max breakaway torque rating of 1400 ft-lbs. The only negative with this model is it’s weight, the sucker is heavy especially compared to the 20 volt impact driver I use regularly in construction situations.
I think as time goes by I will add some more tools like a 3/8” drive model that’s more compact as I found that I need something that I can remove the rear wheel on the Wing, possibly even a ratchet style if it has enough torque rating to get the job done.
cutter
Plantersville, Texas
« Reply #7 on: January 30, 2025, 05:18:36 PM »
I got one of those for my wife and daughter for the horse trailer. I'm not always available due to work schedule. It's much better than the 4-way lug wrench.  cooldude
« Reply #8 on: January 31, 2025, 06:10:51 AM »
I have the 3/8 Craftsman impact and it takes the RV trailer wheels off and on with ease.  Thinking about one of the 1/2" drive models for the Ram dually.  I don't know if I could break one of those lug nuts loose....
Hay  Cool
« Reply #9 on: January 31, 2025, 06:32:14 AM »
Hay  Cool
Even if you could, when you get to be 72, it’s going to hurt some! cooldude
« Reply #10 on: January 31, 2025, 07:32:48 AM »
I have the Ryobi 1/2" and 3/8" drive impact guns.
They're good at  removing "Well Torqued" nuts and bolts!
Not a tool that I use often, but it is one that I'm darn glad to have when I need it.
