February 04, 2026, 05:09:24 AM *
Author Topic: Something With Bearings is Going Bad  (Read 2156 times)
pc shaun
FL Panhandle
« on: February 17, 2010, 07:26:07 PM »
I have a 98 standard with around 38,000 miles on it.  Lately I have noticed what sounds like bearings chirping and once in a while (very seldom) what feels like something grinding.  I replaced the wheel bearings a little over a year ago around 28,000 miles.
From what I can tell it takes the bike around 4-5 miles of warming up before the chirping starts.  It doesn't chirp when it is in neutral or when I engage the clutch only when the bike is in gear.  Also it doesn't seem to occur when I apply throttle, but I notice it as soon as I let off.
Hopefully somebody can help diagnose what is going on.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: February 17, 2010, 07:36:49 PM »
Sounds more like a cracked or split vacuum hose from one of the carbs.
« Reply #2 on: February 17, 2010, 08:40:02 PM »
If you're quiet with power on and noisy when you let off, it might be a U joint. I changed a blown U joint for a friend at 43K. I changed mine at 92K just for grins and it was still good.
Mr.BubblesVRCCDS0008
« Reply #3 on: February 17, 2010, 11:24:46 PM »
Also   check the  driveshaft and coupler at the final drive. It's not a good thing to lose one of this miles from home.
« Reply #4 on: February 18, 2010, 04:14:17 AM »
Just to clarrify.......are you saying it does this chirping while moving and NOT moving.  Or is it only while moving?
Wheel bearings can be bad very quickly if they were installed improperly or if after they were changed at some point the axle was over torqued.
A quick check of the wheel bearings is to put the bike up on a lift and try to move the wheel side to side (laterally) listen and feel very carefully...if there is even a tiny tic left to right, you probably have a bad bearing
RP#62
Gilbert, AZ
« Reply #5 on: February 18, 2010, 04:48:52 AM »
While its chirping, if you pull in the clutch and it immediately goes away, its the clutch pushrod chirping.  If thats the case, sometimes the chirping will go away by it self, sometimes it will persist until you lube the pushrod.
-RP
« Reply #6 on: February 18, 2010, 08:56:50 AM »
Listen to Valker!  It's that and the whole smog stuff that you need to trash can.  Always a problem.
pc shaun
FL Panhandle
« Reply #7 on: February 18, 2010, 06:25:50 PM »
Thanks for all of the replies.  I will start checking down the list until hopefully one of these suggestions works.
F6MoRider
Lakeland, FL
« Reply #8 on: February 23, 2012, 06:05:55 PM »
I'd suggest checking the u-joint first.  Mine went out at 31000 and the process of it dying was remarkably similar.
For those searching with similar issues, can you update the thread with what you found?
Greg
« Last Edit: February 23, 2012, 06:14:19 PM by F6MoRider » Logged
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
