February 11, 2026, 07:23:24 AM *
Author Topic: Grub screw to reolace brake caliper pin screw  (Read 3101 times)
Pluggy
NC
« on: January 29, 2025, 01:14:33 PM »
There was a post recommending a grub screw to replace the slotted "pin plug screw" on brake calipers.  The replacement screw uses an Allen wrench rather than a flathead screwdriver.  I can't find that post.  Does anyone know what screw to order?
« Reply #1 on: January 29, 2025, 02:43:03 PM »
If you take the screw you are replacing to Ace Hardware they have a board of threaded examples you can use to decide what you need in the replacement.
Pluggy
NC
« Reply #2 on: January 29, 2025, 02:54:51 PM »
I just measured one and it appears to be M10 x 1.0 x 6mm tall.  Sound right, guys?
Willow, the closest Ace is over by Pinehurst.  Wealthy neighborhood.  They have a wine department but probably won't have the screw we need.
« Reply #3 on: January 29, 2025, 03:02:12 PM »
here's my post
https://www.valkyrieforum.com/bbs/index.php/topic,125567.0.html
Found a Allen Socket Head Plug to replace the OEM flat screw driver plug.
0.5 mm longer than oem but not a problem. Socket end could be shorten some if one wanted to.
after install I put a chrome cap into the allen socket.
https://www.fittings.space/gsm13-m10x10m-sc
Metric Fitting M10 M10X1 Male Thread Allen Socket Head Plug Black Steel
Pluggy
NC
« Reply #4 on: January 29, 2025, 03:06:08 PM »
here's my post
Thank you.  I did a search for that and it did not come up.
ridingron
Orlando
« Reply #5 on: January 29, 2025, 06:43:57 PM »
Doesn't have to be a "grub" screw.
-mike-
Germany
« Reply #6 on: January 30, 2025, 04:07:51 AM »
https://web.archive.org/web/20210413185014/http://valkyrienorway.com/Techpinplug.html
That's what I did.
Just take any M6 stainless Allen bolt, polish it's head, cut m10x1 thread, dremel the head off.
Deburr and ready to mount.
-mike-
« Last Edit: January 30, 2025, 04:10:28 AM by -mike- » Logged
Pluggy
NC
« Reply #7 on: January 30, 2025, 07:00:34 AM »
Thanks, guys.  I learned that Niissin calls the item a plug, and it is 5.6mm tall.  There are stainless and titanium hex head versions available as a GL1500 custom part.  At 5.6mm, there would not be much depth for the Allen wrench.
eBay has a 20 pack of steel, hex, 8mm tall for $9 and I will evaluate them.  The hex head can allow an owner to overtighten the screw and damage the caliper.  Using a handheld screwdriver on the Nissin plug probably won't get tight enough for damage.
Loosening and tightening the pins and plugs a couple times a year would probably keep them free running.
« Last Edit: January 30, 2025, 09:47:07 AM by Pluggy » Logged
-mike-
Germany
« Reply #8 on: January 30, 2025, 12:01:23 PM »
Or just use some Anti Seize für any steel screw in aluminum.
I have learned this the hard way  with corroded alternator screw(s).
Valker
Wahoo!!!!
Texas Panhandle
« Reply #9 on: January 30, 2025, 01:58:20 PM »
The OEM cap is also slotted for a JIS screwdriver, NOT a standard American flat blade.
« Reply #10 on: January 30, 2025, 02:41:57 PM »
plug torque rating  pg 15-1
2.5 Nsm (0.25 kgf-m, 1.8 Ibf-ft)
Pluggy
NC
« Reply #11 on: February 17, 2025, 04:06:34 PM »
Follow-up on the grub screws.
https://www.ebay.com/itm/364532240299?var=634037426817
High quality.  They extend about 2mm from the caliper casting so there's plenty of depth in the hex for an Allen wrench.  A dab of anti-seize is appropriate for a plug like this (not recommended for fasteners).
We must resist the urge to overtighten.
