February 11, 2026, 07:23:31 AM *
Pages: 1 [2]   Go Down
Author Topic: Starting fresh  (Read 6042 times)
« Reply #40 on: February 25, 2025, 02:49:42 PM »
What are good places to get all this from?
I've had good luck with Rocky Mt ATV for OEM parts.
I only use OEM brake pads and I use the Interstate Rear Pads in all calipers.  Just got to remove the heat diffuser metal pieces to fit the front calipers.
Some good, maybe dated, info here.
https://www.jkozloski.com/generic_parts.htm
I'd swap out the coolant.
If after checking the timinig belts for cracks or damage, if good, I'd let them be.  Same with plugs.
« Last Edit: February 25, 2025, 02:59:16 PM by Hook#3287 » Logged
mello dude
Dayton Ohio
« Reply #41 on: February 25, 2025, 03:45:51 PM »
On OEM parts, I ususally will order with my PC... and open a tab for each parts vendor..
RockyMountain ATV/ProCaliber/RonAyers/Partzilla...
I'll set up my order on each site... then the one with the lowest cost and parts available get the order.
Much of the time, the winner is RonAyers.  cooldude
Avanti
Stoughton, Wisconsin
« Reply #42 on: February 25, 2025, 07:10:47 PM »
Ron Ayer’s always
« Reply #43 on: February 27, 2025, 05:28:00 AM »
I've done the same many times and the deference is not great when taking into consideration min order for free shipping.  At least that's what I remember.
Rocky mt atv seemed to have everything in stock and with 2 warehouses, the orders were filled, shipped and received quicker.
Just my experience.
Most suppliers seem to do good.
Quince
« Reply #44 on: February 27, 2025, 05:47:33 AM »
What is a good supplier for timing belts, tensioners and other hardware like springs for the timing belt job? Thank you.
« Reply #45 on: February 27, 2025, 06:09:12 AM »
Amazon has the Gates T275 belts, you need 2 of them.  As for the tensioners/springs, I use OEM.
https://www.amazon.com/Gates-T275-Timing-Belt/dp/B000CRDMS8/ref=sr_1_1?crid=9AZI60Z4XDQ4&dib=eyJ2IjoiMSJ9.8lygbQb5GBeUQKoAIwxR2UR8o3iYlFZCfhb65-TgH6a8Zo8Ru04OMAX1Q_8S-jB43i0um6dXFNtk28l9haTN67E-TYsKk7718jBQmqnfiXpYhcPQdqmE3dszQOuxUIhbl4WMsg6ugaUsz8kBIQXJb99efIoi7i9zcclIzcRkth1MBUvZUs7vdKdiyXzVpCsA9D4pnhgOEtM0j7HTKaLHn3E6i4Ux5oVgmt1BtShsbyA.lfprgJGKO1EVwPg4HubBzd7HnpGmi843Yu6X7EMIaak&dib_tag=se&keywords=gates+t275+timing+belt&qid=1740665211&sprefix=gates+t275%2Caps%2C197&sr=8-1
Hay  Cool
« Reply #46 on: February 27, 2025, 07:20:37 AM »
About any auto parts store will have the belts.
Timing Belts
Gates # 275
Napa # 250275
Goodyear - #40275
Pages: 1 [2]   Go Up
